Question about KitchenAid Dishwashers
Our kitchen aid dishwasher mod KUDE03FT is not draining. We have checked to breaker box and no breaker is tripped but it is as if the front panel is dead even the drain button will not respond
SOURCE: Kitchen Aid Dishwasher Not Draining
There is a knock out plug on the garbage disposal that probably wasn't removed.
Posted on Jun 24, 2008
  • 3 Answers
SOURCE: Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
SOURCE: Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
Posted on May 05, 2009
  • 670 Answers
SOURCE: KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Posted on Jul 18, 2009
Macmarkus
  • 2605 Answers
SOURCE: Kitchen Aid dishwasher has no
Welcome to FixYa.
Based on your brief description, I'd suggest you likely have a faulty thermal fuse in the control board as you alluded to, but it is not resettable unfortunately.
It's pretty easy to replace or to check, I've attached a link below to change the fuse, but you can also use the link to access the thermal fuse to check it.
With the aid of an ohm meter, remove one wire and measure across the two contacts and it should show continuity, otherwise it's open and therefore no good.
The part is available at most brick & mortar part places or on-line at vendors such as "repairclinic.com" or searspartsdirect.com" to name a couple. Part number 8193762...looks like this image and retails for about $15-$20USD based on the model you provided.
This is the youtube link to help with the repair "how to".
http://www.youtube.com/watch?v=jdlVbTXm8SY&feature=player_embedded
Let me know how you make out or if you require any further assistance and I'll try to help in any manner I can. Good luck.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Apr 17, 2011
My double drawer kitchen aid dishwasher is stuck on rinse mode
I tried this once an it worked. Tech came from Sears an asked where fuse box was. He tripped the breaker for dishwasher. Flipped it back on after 10 seconds. Came to the dishwasher an it was like new again. He said sometimes they need a reset. If that did not work he had to replace the panel. Hope it works for you.
Jan 28, 2015 | KitchenAid Kitchen Aid Architect II 24 In....
Defy dishmaid DW12
You have a major short to ground which is tripping the breaker. Get an electrician to check the machine, it may be as simple as you have trapped the cable. Don\'t mess with water and electrics. Electricity is the silent killer.
Aug 21, 2014 | KitchenAid Kitchen Aid Diswasher Part...
Kudi02cr Kitchen aid dishwasher not turning on. No lights nothing
check your breaker panel to see if the dishwasher breaker might be tripped. then be certain that the door is closing all the way and engaging the safety switch
Jul 04, 2014 | Dishwashers
Kitchen aid Model#KUDSO1DLWH3, stopped working. No lights, No function. Circuit breaker ok. water in bottom of tub
CHECK FOR VOLTAGE TO UNIT, CHECK THE WALL SWITCHES, CHECK THE GFI OUTLETS FOR TRIPPED.
Mar 09, 2010 | Dishwashers
Kitchen aid dishwasher with blinking lights. Manual says to call service tech.
and so you did / im a service tec . need more info th help . like mod and ( kitchen -aid ) . try looking in the front toe panel for a tec sheet this will tell you about the blinking lights and what the mean . get back with me if you need more help //mm fed back pls .
Dec 17, 2009 | Refrigerators
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Jan 08, 2009 | Bosch Dishwashers
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Dishwashers Logo
23 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
