Question about LG Cell Phones
I have a LGVX 8360,and when i plug the charger in it goes into a non-charging mode,also says the battery is not compatible.If i just plug it in just slightly,it seems to charge. do i need a new battery,mine is not a year old yet,or a new charger?The car charger seems to work fine.Thank you.
  • migoss979 Sep 03, 2010
    yes thank you
    President:
  • 1,932 Answers
As your car charger seems to work fine and when you adjust the charger it works fine,So the problem is with your charger only.So please get the new charger and this will solve the problem.
Thank You
Posted on Sep 02, 2010
HP Pavilion battery wont charge when charger first plugged in.
1. AFTER WINDOWS LOADED THE PUT YOUR CHARGER TO LAPTOP
OR
2. CHECK YOUR BIOS TO ALLOW NON-OEM BATTERY
OR
3. USE STAND ALONE CHARGER
Sep 21, 2012 | HP Pavilion dv6t Notebook
Just want to know what the code FLO stands for kid lost the manual
The digital display shows "FLO" to indicate that the unit is in float charge mode. The battery "fully charged" icon will display on the LCD screen and the arrows pointing to the "+" and "-" will flash. In this mode, the unit monitors the battery voltage and charges as necessary to assure the battery maintains full capacity. The unit remains in float charge mode as long as the charger is connected to the battery and plugged into a functioning AC outlet. I hope this has answered your question.
Apr 01, 2011 | Stanley Black & Decker Stanley Bc1509 15...
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is...
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
Plugging 18v battery onto charger....it goes into pre charge mode (no lights) and stays there. Won't charge. Good power to charger and same results with two different batteries.
Either all of these batteries are at end-of-life or the charger internals are defective. Try a known-good battery first, then look into the charger with a voltmeter. The charger should deliver several volts higher than the rated voltage of the battery when the battery is inserted.
Feb 02, 2010 | Drills
Non microsoft battery won't charge on a microsoft charger
Well... try to stick with 2 brands of batteries not seprate if i don't inform me my address is addisonswim@hotmail.com
Oct 03, 2009 | Nyko Charge Station 360 For Xbox 360
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
How do I know that the GPS is charging. The light is green when pluged in. Should it not be red then go green Lorraine
On a Nuvi 200W, when you plug in the charger, the battery status icon should go away indicating that you are no longer on battery power and that you are now running on an external power source. You should also hear a beep when you plug in the charger.
To go into charge mode, move the on/off switch to the left like you would be going to turn it off but only hold it on long enough until you hear it beep or the screen goes black and says "Battery Charging". When the battery is fully charged, touching the screen, it should say "Battery Charge Complete". If its not fully charged, touching the screen, it will say that it's still in charge mode.
- Jim
SHARCNET-USA
Feb 25, 2009 | Garmin nuvi 200W GPS
Kodak Easyshare Z1285
Are you using the batteries listed as compatible according to the cameras battery door? Or are you using NON-compatible Alkaline or Ni-Cad batteries? Only Li-Ion and Ni-MH are compatible. Hope this helps...
Jun 29, 2008 | Kodak EASYSHARE Z1285 Digital Camera
Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Dec 25, 2007 | Canon PowerShot G2 Digital Camera
Cell Phones Logo
23 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
