Question about Kenmore Dryers
Hi, I have a kenmore gas dryer Model # 11077532600. When I first turn it on the gas runs then shuts off after about 5 to 7 minutes. I experienced this problem a year ago and we had the thermal fuse replaced. At first I though it was the same issue and replaced the thermal fuse, to no avail. The same problem happens when I remove it from the venting, any advice would be greatly appreciated
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Hi I have a kenmore elite oasis dryer. And all of a sudden it only will run for about a minute and then it shuts off. I tried turning it back on again and it does the same thing. Then after the third time...
The first suggestion I have for you is to simply run an Air Fluff cycle with no heat.
If the Air Fluff cycle runs okay then the problem is most likely with the thermistor.
You can try to run the dryer with the vent hose off and see if there is a difference.
Oct 07, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
I have a Kenmore Elite gas dryer - model # 110 70052990. Just hooked it up after a year of not using it and it continues to shut itself off on Normal dry (begins at 40 minutes) and shuts off at 38 minutes....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
I have a kenmore gas dryer model 70722990 when you turn it on it has a very high pitch squeal sound runs for 5 minutes then turns it's self off and won't turn back on. can you please tell me whats going...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Kenmore Dryers
Sears model dryer 110.78932790 hesitates, turns on, shuts off
The motor is going bad...
You need to replace the motor...
Here is a tip that will help also..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 27, 2010 | Kenmore 72062 Gas Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Mar 27, 2009 | Kenmore Dryers
Kenmore Dryer Gas 110.73942101
Hi. thanks for the question. The problem you have is with a motor. it gets hot, and cuts off. pull dryer away from wall. clean venting. remove back panel, clean all dust. that will solve your problem thanks the appliance doc
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Dryer only runs for 15 minutes and than shuts off and won't turn on. when it cools down it will start but only run for 15 minutes it is a kenmore gas 1109728110072811 thanks
It has a bad Motor and requires a experienced repairman to install it.The longer you use this motor it eventually will just make a buzzzzz sound. Please rate this !
Jun 14, 2008 | Dryers
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
MY KENMORE MODEL 110.76722694
You have a bad motor. You can remove and verify probably bad bearings and burnt start winding.
May 16, 2007 | Kenmore 74992 Gas Dryer
Dryers Logo
69 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
