Question about Bushnell 3" Reflector Telescope w/Talking Guideand Tripod
Setting up scope
It says in the instructions to look for a black arrow below the azimuth mount. All I see is the white arrow for the degrees. I am having problems alighning the telescope. Howw should I do it?
  • 57 Answers
If background is black arrow must be white.No problem.Go to sky whatching.
Posted on Jul 12, 2011
After getting scope on bullseye,what do they mean by,Zero setting of scale grip? my scope is a Nikon Bolt XR, for crossbows
you need to decide what distance you want bullseye to be. the arrow in flight is either rising or falling. if you get bullseyes at say 50 yards you will be low at 25 yards (arrow rising) and low at 75 yards (arrow falling). this is due to the scope is mounted higher than the arrow.
Sep 22, 2013 | Nikon Bolt XR Crossbow Scope Black Matte...
I don't know how to use your telescope Please help me
We will need much more information-- what type of scope do you own? A refractor? a reflector?
And is it mounted on an altitude azimuth mount or an EQ - equatorial mount?
Aug 01, 2011 | Optics
I inherited a blue Skywatcher telescope about 4 years ago without instructions . it has D = 70mm and F = 900 mm printed on the side . it came with two eye peices and extender and a 45 Degree 'erecting...
Any manual for a 70mm (refractor?) style telescope will show you how to set this up. You never said what type of mount the scope is on-- Altitude-Azimuth, up down left right--- or an equatorial mount??
Anyway Meade has manuals for all of their telescopes available for free download. Go to the Meade site listed below and look under the REFRACTOR heading (or the 4.5 inch REFLECTOR) heading for one that is similar to your scope. They are all assembled and used in a similar fashion.
http://www.meade.com/manuals/index.html
and look at my TIPS on my profile page-- and read this web site-- to learn about the types of telescopes and mounts:
http://texasastro.org/telescope.php
http://texasastro.org/mounts.php
Jun 04, 2011 | Optics
Hi, Bought a used telescope with a GT mount. The polar adjustment will not go below 46 degrees without binding. The binding screw only turns 1/4 turn in each direction and appears to be binding the...
This scope does NOT need to be polar aligned --
Here is the manual:
http://www.celestron.com/c3/images/files/downloads/1228334587_nexstargt.pdf
This is an ALT AZ goto scope. Read the manual above. You use the hand controller to move the scope in Altitude and Azimuth(left-right).
You must align it on 2 stars in order for it to has successful gotos.
Aug 21, 2010 | Celestron NexStar 114GT (269 x 114mm)...
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Celestron 114EQ polar setting and Equatorial settings
The ALTITUDE adjustment matches your LATITUDE. I live at 32.5 degrees North latitude. So the scope is first adjusted to 32.5 degrees UP.
Then the Right Ascension is point to Polaris the North star by MOVING the entire scope and mount.
Read my Equatorial mount TIP on my profile page, and read this web site.
http://www.astro-tom.com/tips_and_advice/precision_polar_alignment.htm#Rough%20Polar%20Alignment
May 05, 2010 | Celestron PowerSeeker 114 EQ Telescope
The azimuth adjustment keys don't work
Send it back along with the hand controller describing the problem. Could be several things including a bad hand controller. If there is a local astronomy shop nearby take the scope there and ask to try one of the hand controllers in the shop and test it. If it now works you just need to buy another hand controller.
Otherwise send it in for repair
Jul 01, 2009 | Celestron NexStar 5 SE (300 x 44.45mm)...
The Azimuth Dial isn't firmly attached cause altitude cannot be fixed to an angle
Most of the small telescopes setting circles really cannot be used to find anything--- just not accurate enough---
Try using a star chart -- and star hopping --- to what you want to see.
A free monthly star chart is available at :
www.skymaps.com
Jan 03, 2009 | Bushnell Voyager 78-9945 Telescope
One of the gears in the Azimuth motor got a flat spot because the worm gear was adjusted too tight. It is a 24 tooth nylon straight gear, very small- only about 1 cm across, but if this gear isn't working...
Below is the contact information for Meade parts. They are the only reliable source unless you know a local dealer that you can trust.
http://www.meade.com/support/contact.html
Jerry G.
Meade Instruments Corporation
6001 Oak Canyon
Irvine, CA 92618
(800) 626-3233 (U.S.A. Only)
Fax: (949) 451-1460
Apr 30, 2008 | Meade ETX-90 (48x90 mm)
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Bushnell 3" Reflector Telescope w/Talking Guideand Tripod Logo
94 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
