Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have a c652 biz hub keeps coming up waste toner box konika minolt printer
    Problem Solver:
  • 10 Answers
To replace the waste toner box, open the front door above the paper drawers. The waste toner box is on the left hand side (usually). Your supplier should have supplied an extra waste toner box. Slide out the 'full' toner box. Replace with an empty one. This should register that you have installed an empty waste toner box. If not, turn off the copier and after a minute or two, turn on the coper again. [If you want to be environmental friendly, the toner box has a small slide cover approximately 1-2cm long (usually on the upper face at the rear as you remove it). Place this end in a plastic bag, slide open this 'cover' and rotate the toner box 180° so this is facing down. Care needs to be taken to prevent the 'waste toner' from flying everywhere. Gently agitate the box until all the waste toner (a grey color) has spilled out. (Approximately 600-800gms) Carefully seal the bag and dispose. An industrial vacuum cleaner can be used to remove the residual toner, clean down the waste toner box with a soft rag and it is ready to re-use.]
Posted on Sep 03, 2010
I keep getting an error message stating to install a waste toner box and close all doors.
Printers usually have a waste collector where excess toner is collected. Obviously, yours needs to be changed.
Mar 07, 2016 | Konica Minolta Bizhub C452 Color Copier,...
I keep getting a message install waste toner box and close all doors, i have tried all that and the message keeps coming, the waste toner box is empty.
remove the toner, check if there is any debris perhaps also blowing in the guides of the toner. Give it a shake and refit it.
Close the doors and if you still get the message you need to replace the empty toner
Mar 11, 2015 | Office Equipment & Supplies
I have Konica Minolta C652. I emptied toner box & placed it back but then the screen is telling me to install toner box & close all doors.
In the middle of the Box there is a see thru dark plastic , a lip , that goes inside the the sensor , when the box gets full of toner it blocks the light that goes thru it, when you emptied the box the plastic inside was still dirty, Replaced box or clean the box from inside
Dec 17, 2014 | Konica Minolta Office Equipment & Supplies
Where is the waste toner box for Konika Minolta C250
open the front door to the left and towards the bottom it pulls out towards you just lift up a little it has a blue sticker on it got a cell number ill send you a picture
May 27, 2014 | Konica Minolta bizhub C450P Laser Printer
Biz hub c35 remove waste toner botle
located below the image unit follow instrution and replace
Feb 04, 2014 | Konica Minolta bizhub C250 All-In-One...
HOW CAN I REST SERVICE CODE ON A KONICA MINOITA BIZ HUB C652
Reset the machine. If the code doesn't clear then you either have a fuser code which may or may not be an issue. It has to be set differently. Turn machine off. Hold utility. turn machine on while holding utility. It will bring you to trouble reset screen. Click button on screen and reset the machine. If code comes back, you have a broken part of some sorts. Whats error code?
Jan 23, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c 2204 on konica minolta c652
Waste Toner Motor failure. check the waste toner box might have a issue where harden toner damaged the gear drive and or motor that takes care of the waste toner. worse case the control board is damaged $$$$$$$$$$$$$$$$$$$$$$$$$$$$. Have a tech come out mite require replacing some gears.
Jan 22, 2014 | Konica Minolta bizhub Office Equipment &...
How do i replace the waste toner box on the konica minolta
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Jul 31, 2008 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,174 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
