Question about Protron PLTV-3750 Television
No power light on TV, power at outlet, acts like internal blown fuse
I am not getting the red indicator light that power is available to TV, checked wall, outlet has power. Any thoughts.
    Problem Solver:
  • 3 Answers
Make sure your main switch near the power cord where fits in the tv is on,if it is and you have power in the outlet you have a power supply problem.i sugest to take it to a repair shop.I am a technician but i am in Puerto Rico otherwise i would be more than happy to fix it for you.I have a good experience with these tv and have fix a lot with thesame problem.
Regards and good luck,
Jorge.
Posted on Aug 24, 2008
Turn tv off left for weekend came home no red light no power
check the power cable and socket, and also check the fuse of the TV by opening the back panel.
Mar 19, 2015 | Televison & Video
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
No power to monitor. Red light does not come on.
Hello The TV is completely dead no power indicator,nor standby light. Probable main fuse failure, but first make sure your AC feed is present, try another electrical fixture in the TV ac outlet you are using to make sure the outlet is alive. If this is not the case then check the main fuse(located inside the TV) not recommended if you are not qualified to work on electronic equipment. A blown AC fuse usually is an indicator of more serious problem further in the power chain(power supply/HV circuits, etc.)
Nov 24, 2010 | Fujitsu Plasmavision 42" TV
Green power light blinks for 1 minute then the lamp light blinks
When Lamp of the TV has been blown out, the LAMP light blinks in red.
When there is an internal malfunction in the TV, the Power led blinks and there will not be any picture on the screen.
Since, both are happening with your TV, it seems that there is an internal malfunction. Hence, your TV requires service.
You may try the following troubleshooting steps before getting the TV serviced.
Disconnect the Power cord from the Wall outlet and connect it to a different working wall outlet.
Disconnect surge protectors if you are using.
Then try resetting the TV to the Factory default settings to check whether the issue is resolved.
Jul 14, 2010 | Sony KDF-E42A10 42 in. LCD Television
Ilo tv will not turn on. I was able to unplug the tv, plug it back in and then it would turn on. Now, nothing works.
is there power came from your outlet if yes then check your power filter fuse if OK then check your audio board because it act as output and crossover power that is depend only if you have red light on,also check your power supply board for blown capacitors. also get another opinion good luck.
Apr 28, 2010 | iLO 2600 Television
No Lights, No Power Indication. No Beeps. Power IS available at outlet. Thanks,
Check for a blown thermal fuse. It's about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Sorry for your trouble and I hope this helped. Best wishes.
Sep 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Red power light is unlit, TV is unresponsive
This has most probably blown an internal fuse in the power supply. Most have a surge protection type fuse. It is best to have a repair engineer have a look at it as the fuses are specially rated for safety.
Mar 28, 2009 | LG 42PC5DC 42 in. Plasma HDTV
No red light on TV so doesn't turn on, yet cable box lit
hello, check you power cable make sure it is properly attached.
test your power outlet, also try using another outlet if possible,
try reseting your fuse box switches.
if it is not your outlets then you may have a fualty power supply, if theres no red light means theres no power reaching the internal circuts it may be numerous reason for this or even a simple blown fuse on the powersupply, but basically no red light means no power.
unfortunatly one or more of your internal board may need to be serviced or even replaced this is not something you want to do your self the voltages inside of these systems are very dangerous and you need model specific service manual,schematic, and electronic circut test equipment. if your electronically inclined you can check to see if your fuses are blown but i dont recomend it unless you have some basic safety and electronics training.
besides this most of these tv's need to have there voltages tested and adjusted after board replacements.
suggestion: search for a qualified service center who can give you a estimate for repair, search around some companies offer free estimates
and will even come out to your home and check and repair your tv on the spot.
if it is under warantee you may be able to get a replacement or repair without charge. if not then get your estimate find out whats wrong and find out what service center offers the best price for the service or repair.
hope this helps
good luck and happy holidays
Dec 11, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
36" Sony Wega - no power
There are of course internal fuses, but I suggest you better call a technician if you are not an expert, because you can blow the tv trying to rectify power supply problems. If the fuse is blown, there must be a faulty component behind that.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Televison & Video Logo
134 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
