Question about Samsung Refrigerators
I have purchased a new samsung rt29cdlb1/xtl refrigerator.But its sides are getting very warm.Will it continue like this? This is quite annoying.
  • 41 Answers
SOURCE: ICE MAKER HAS QUIT WORKING
take off the cover to the ice maker. make sure the 2 tabs in the middle of the main gear are in tack and not broken. if one of those tabs is bent or broken, the gear will not make a full rotation. if the gear is fine, check your fill tube in the back of your freezer that goes to the ice maker and make sure it is not frozen. if it is, it will need to be thawed. does your unit have a water filter? if so,it may be plugged and need to be changed. the last thing would be an issue with the water value itself. Joe
Posted on Nov 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: Warm refrigerator
Check the freezer fan.
Is it running?
If not, replace fan motor.
Check the damper doors in the fresh food side.
Does air flow through?
Posted on Mar 09, 2009
landsend
  • 1066 Answers
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Posted on Mar 27, 2009
SOURCE: The refrigerator portion has quit cooling.
I have the same problem and have found that if you take the panel off inside the refrigerator and with a blow dryer defrost it. It should work for a few weeks. I have been doing this once a month since March and I hope to found out how to fix it also.
Posted on May 18, 2009
SOURCE: In my side by side samsung RS2534WW the rerigerator is warm
I read elsewhere that if you hold the power cool and power freeze buttons down for 12 seconds it will restart the system. I did it the other day (because we were having the same issues) and it has seemed to work for the last few weeks. Frige temp stays at 34F and freezer temp stays at -2F
Posted on Jul 04, 2009
Cooling problem in my Samsung rt29cdlb1/xtl
Hallo
Low humidity in your area set the thermostat colder or its the thermostat not switching of at the right temp.
Regards.
Jun 21, 2016 | Samsung Refrigerators
I have Samsung 230 ltr double door refrigerator with model number RT24BDTS1/XTL/2010.
The thermostat is defective and needs to be replaced with a new one.
Jul 24, 2015 | Samsung Refrigerators
Samsung refrigerator single door 180 ltr model : RA18QHDR1/XTL Refrigerator not working. Light is on. Compressor not working. Service engineer said: Relay and OLP damaged. How to change? what is...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 05, 2011 | Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
We just purchased the fridge one week ago. It hums quite loudly for lengthy periods, which is annoying. I don,t think that a brand new fridge should be doing this.
i have a hotpoint freezer that does the same for about 15mins every hour.........thats new too.so i moved it into the garage.....
Aug 27, 2010 | Samsung Refrigerators
Kitchenaid Refrigerator door gaskets are getting very warm.
When the center divider gets hot, it usually means that your condenser fan (the one that blows air across the coils under the fridge) is not working, or that the condenser coils are extremely dirty. Next time the fridge is running, see if there is any air blowing underneath. You probably need a new condenser fan.
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Samsung French Door Refrgerator - New
Only two months old? Couldn't you complain to the store?
The way the defroster works is this: There is a defrost timer under the refrigerator. (I'm guessing based on other brands.) That turns on the defroster about three times per day. The defroster is a heating coil with the freezer coils. It heats that until the defrost thermostat gets warm; then it quits defrosting.
My guess is that the defrost thermostat doesn't turn off the defroster... that it continues defrosting until the defrost timer turns the defroster off.
So if you want to fix it yourself, dig into the defrost coils. I don't know where to look on a French Door refrigerator. Find the defrost thermostat, an inch wide unit with two wires. Test it for continuity while it is warm. There should be none. Frozen there should be continuity.
Hope that helps.
Jun 13, 2008 | Refrigerators
Kenmore - Constant humming, clicking sound
ok if little or no cooling suspect defective relay/overload combination.
Mar 25, 2008 | Kenmore 44103 Side by Side Refrigerator
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Dec 22, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
77 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
