Question about Panasonic SA-HE70K
Panasonic SA-PT480. I want to watch Panasonic TV (no sound) and listen to ipod simultaneously through ipod dock. Currently I have to either view the ipod on the TV screen (ipod nano) or let the songs play randomly (iphone 4). I can't manage playlists or choose a particular song.
bstimpy
  • 47 Answers
SOURCE: no sound through Panasonic SA-HT930 surround system
I've had similar problems in the past. With audio problems trace the problem from the source to the amp.
1. What output is the cable box using for audio, digital or analog?
2. Is there a setting in the cable box to switch between digital and analog?
3. Once you have determined the output of the cable box check to make sure that it's going into the right output on the panasonic
4. This is where the problem usually is...what is the receiver expecting for sound, analog or digital?
5. Switching between the sources...the sound should be on one of them.
Posted on Mar 19, 2008
  • 93 Answers
SOURCE: PANASONIC SA PT560
Need more details,you not too clear on your subject!
solutiondoct
Posted on Nov 06, 2008
SOURCE: cANNOT WATCH iPOD mUSIC vIDEO on Panasonic SC-PT865
Maybe because is only read audio, like Photos and mp3 audio only, expecially if read format llike "High Mat" to read photos and music, try to go to instructions manual and see the format what your dvd read.
Posted on Jan 15, 2009
sonicboomele
  • 1557 Answers
SOURCE: Panasonic SA-PT480 will not turn on after power
it sounds to me like you have endured a power surge and it has cooked the unit // i would replace it as surges do so much damage it normally writes the unit off but your power company is liable to replace it (if it was a surge)
Posted on May 15, 2010
  • 154 Answers
SOURCE: Just wondering if there is any way to hook an iPod
only in stereo, there is not digital interface for this sound system, you need a 3.5mm jack to RCA lead (Head phone connector on end and a red and white phono connectors on the other) these connect to the Aux 1 or Aux 2 inputs on the rear of your stereo.
Posted on Jun 20, 2010
Can I use a Philips universal remote for a Panasonic SA-PT480?
It is quite likely you will be able to find a code in your Philips URC that will handle some or all functions of your Panasonic SA-PT480.
Mar 17, 2016 | Philips Televison & Video
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
How do I mute sound so as I can listen to Blue Ray through headphones
Usually, you should connecct your headphones to your TV, which will mute the internal speakers.
Sep 17, 2014 | Panasonic Sa-bt230 Blu-ray Disc Receiver
Setting up ipod video
According to page 34 of your owners manual, your docking station will only allow you to listen to audio from your iPod/iPhone. Video on your yamaha can only be viewed via composite, component and HDMI sources.
Apr 29, 2012 | Yamaha Audio Players & Recorders
Im tryna hook up my pansonic sa-pt 480 surround sound to my 42 inch plasma panasonic flatscreen and the cable but the sound not coming out the speakers
I couldn't find any info on sa-pt480 only scpt480. However, setup should be straighforwardly the same.
Generally you have to direct the sound in setup. The manual is here http://www.mito-oem.com/media/pdf/SCPT480.pdf Follow the instructions for setup
Mar 13, 2011 | Audio Players & Recorders
I have a Belkin TuneCommand AV. It was given to me a couple of years ago. I found it this morning, and do not have a clue how to use it, nor even what its function is. I leave for Mexico, South America and...
  • Your device is used in conjunction with an iPod music player. It is a base to charge it and if you have the remote you can play songs from across the roo.
  • Compatibility: iPod 3G, 4G, 5G, 6G; nano 1G, 2G, 3G; iPod touch; iPod mini
  • Lets you watch and listen to your iPod player through your home entertainment system, while simultaneously powering and charging it through the docking station
  • Includes a remote control that uses wireless radio frequency (RF) technology and works from up to 120 feet away, regardless of barriers such as walls, ceilings or windows
  • Basic functions include: play/pause, next/previous track, volume up/down, song shuffle, and repeat
  • Cradle that comes with this unit connects to your home entertainment system via an included A/V cable
he Belkin F8Z065 TuneCommand A/V Dock with Remote for iPods lets you watch and listen to your iPod player through your home entertainment system, while simultaneously powering and charging it through the docking station. The included wireless remote control allows you to roam freely as you play your tunes from virtually anywhere in your home.The remote control that comes with the F8Z065 A/V system uses wireless radio frequency (RF) technology and works from up to 120 feet away, regardless of barriers such as walls, ceilings or windows, making it perfect for distributed audio systems. The TuneCommand A/V's eight basic functions include: play/pause, next/previous track, volume up/down, song shuffle, and repeat. Used with your iPod video or photo, TuneCommand A/V even lets you watch your downloaded videos, or view your photos on your home television. The cradle that comes with this unit connects to your home entertainment system via an included A/V cable, and it docks, displays, powers, and charges your iPod all at once.
Compatible with any iPod with a dock connector--including the iPod nano 1G, iPod nano 2G, iPod mini, iPod 3G, iPod 4G (Click Wheel), iPod color, and iPod 5G/5.5G Video--via the included interchangeable trays, the F8Z065 comes in a white that perfectly complements your iPod, and it's backed by a manufacturer's 3-year warranty.
What's in the Box
Belkin F8Z065 TuneCommand station and remote, interchangeable iPod adapter trays, surface mounting hardware, user's guide and warranty information.
Product DescriptionTuneCommand lets you roam and play your tunes from virtually anywhere in your home, delivering the flexibility and convenience that iPod users desire. Using wireless radio frequency technology, the TuneCommand Remote works from up to 150 feet away, regardless of barriers such as walls, ceilings, or windows that limit traditional remotes. Connect your iPod to headphones, your home entertainment system, laptop, or computer-even if you stash it away in the glove box, control of your iPod remains at your fingertips.TuneCommand includes a multi-clip, surface-mount hook and lanyard, providing a variety of options for securing your Remote on the road, in the car, or at home. It features eight basic functions: play/pause, next track, previous track, volume up and down, shuffle songs, and repeat. When used with the iPod photo, TuneCommand lets you scroll through your slide shows or presentations-wirelessly.
Jun 22, 2010 | Audio Players & Recorders
Want to use Panasonic SA-HT740 for TV sound
Get the TV audio from the Dish box directly to the receiver.
Feb 16, 2010 | Audio Players & Recorders
PANASONIC SA PT560
solutiondoct
Oct 26, 2008 | Panasonic Home Theater System System
No sound through Panasonic SA-HT930 surround system
Mar 17, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HE70K Logo
713 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
