Question about LG WM2487H Front Load Washer
It sounds like a plane revving up its turbines when our LG goes into the spin cycle. The machine doesn't move but the noise of the spinning "just ain't right". Your suggestions please. lance wheeler
    President:
  • 1,932 Answers
The noise is normall when it is in spin cycle,Nothing to worry about it.
Thank You
Posted on Sep 02, 2010
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Jet Plane noise in spin cycle
The bearing in the outer tub assembly is going out and you will need to replace it. Here is the part if you want to order it but you might want to look into buying another machine.
Nov 20, 2012 | Washing Machines
Doesn't spin
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
Apr 29, 2012 | Kenmore Washing Machines
Sounds like the inside is a jet plane while in spin cycle very lose inside like something is loose ore broken like a belt
If the washer is vibrating a lot, then you could have a bad drum bearing. There are also counter weights and shock absorbers that could be bad. The best thing to do is take off the back panel and look inside. many times the problem can be clearly seen. Usually a loud noise like a jet plane on spin cycle means a bad bearing. This can be costly unless you can do the work yourself. The parts are readily available.
May 26, 2010 | LG WM-1832C Front Load Washer
Noise and movement when spinning
Could be more than 1 problem by sounds of this. !st may be that heater is not working and so machine will not advance to rince. As for banging this could be caused by pump failing to take water away. Or on a more seriouse note could be drum or bearings. Normally if bearings have gone then it will sound like a plane going over. I think it is likely heater, or /and pumping failure.
Mar 15, 2010 | Washing Machines
My washer machine sounds like a plane taking off when it goes into a spin cycle
IF ITS A FRONT LOADER ITS PROBEBLY THE REAR BEARING, DISCONECT THE POWER OPEN THE DOOR AND SPIN THE TUB, IF IT MAKES THE NOISE OR RUMBLE ITS THE REAR BEARING,
Jan 16, 2010 | Frigidaire Washing Machines
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
LG WM2487H Front Load Washer Logo
273 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
