Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Will not get cold
Change the filter not making ice not getting cold
  • goodstreet May 10, 2008
    just buzzing
  • Anonymous Nov 10, 2008
    wont get cold, Frost on the back wall of freezer
  • 770 Answers
Is the fan in the freezer running? is the compresser running?? is the condenser fan in the back running is there a heavy frost build up on the back wall of the freezer answer these and we can go from there
Posted on May 10, 2008
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
Kenmore 51564101 does not make ice
What is the complete model number of your unit?
Nov 28, 2012 | Refrigerators
Our ice-maker stopped working on the hottest day of the year!
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Jun 01, 2010 | Maytag MZD2766GES Side by Side...
Ice maker makes ice, but not nearly as much as it used to. What do you suggest. Water flow out dispenser is fine. Filter has been replaced.
I would suggest making sure the coils under the refrig are clean of dust , lint , pet hair , etc . Also , letting the ice build up so it gets closer to the bottom of the ice maker (coldness of the ice will help keep the ice maker cold ) will result in ice maker cycling more often (making ice) .
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
It stopped making ice but cold water option works fine. No clogs visible. Changed cold setting to 7 from 5. Nothing worked. just took out water filter, but can't see how that was the problem.
Put the filter back in . Pour about 1/2 cup of water into icemaker . If it dumps , then replace the water inlet valve . If it doesn't dump and the ice stays in the icemaker , replace the icemaker . Also , make sure the coils are clean of dust etc... Reset the controls back to normal or you could create water freezing in door (dispensor) .
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker only makes cubes. It will not make crushed ice.
Kindly check it could be because of following reasons :
  • Freezer may not be cold enough.
    Temperature must be 5 degrees (Fahrenheit) or colder to work properly.
  • Normal ice making capacity.
    The ice maker will produce between 2.5 to 4.0 pounds of ice a day depending on your model. Side-by-side models come with a large ice bucket and it may take up to three days to fill this container.
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
    Please feel free to contact for further assistance
  • Jan 24, 2009 | Maytag MSD2651 HE Side by Side...
    Water filter lg refrigerator GC-L197NFS
    I have bought this fridge yesterday all plugged in working well got nice cold water but its not filling the ice try inside to make ice? Dont know why
    Dec 23, 2008 | LG LSC26905TT Side by Side Refrigerator
    You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
    Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
    10 yr old Frigidaire ice maker stopped making ice
    check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
    Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
    Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
    109 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
