Question about Lexmark X1270 All-In-One InkJet Printer
Yes.. I have a LexMarkX1270 Printer and I can't get the Power button to come on. I have check the power cord and witht the USB cord and they are both connected correctly. So, can you tell me with the problem could be. It was working earlier in the day and now I can't get it do anything. Deena
    Genius:
  • 1,087 Answers
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Properly secure the power cord in the power adapter. Other end should be plugged to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. Replug power adapter behind the printer and properly secure it. If printer won't automatically turn on, press the power button. If problem continues, it's a possible defective power adapter or a defective printer. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Posted on Sep 02, 2010
Hp C7280 will not power up
Sir/Madam
It's Seem That Your HP Printer Power cord Is not Connected Properly,so I strongly suggest You Check Your Check Your Power Cord Is Connected Or Not If yes then May be Your switch is Not working Correct Or If No Then
Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Reinsert the cartridges, and then close any open doors on the product.
If you receive a prompt to print a calibration page, do so.
Reconnect the USB cable to the rear of the product, and then try printing again.
Hope Your Power For HP Printer Solved By Now,If No Then Go To Below Link URL:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02036357
I Hope Your Power For HP Printer Solved By Now After Click On Official HP Printer URL Link,
In Case You Still Have Problem Then Follow US On For
HP Printer Support
Jan 08, 2014 | HP Photosmart C7280 Printer
Connect usb port
Check all computer connections and cords. Is the powerstrip for surge protector light indicator bar (usually inside the off/on switch itself) on?
All it takes is a pet to walk over it or a foot to bump a cord and break the power connection. Mine do it all the time. Check the power on/off button on the printer to see if it accidently got powered down.
Sep 19, 2013 | HP Officejet Pro K5400 All-In-One InkJet...
Reset my Dell 926 all in one printer
The Dell 926 printer is an All-In-One model that you can use as a printer, scanner and a fax machine. When the printer becomes unresponsive there may be a communication problem between the printer and your computer. To correct this type of problem you need to first verify that the USB connector cable is not malfunctioning. You can do this by resetting the communication settings between the computer and the printer.
y1 Press the "Power" button to turn off the printer. Unplug the power cord from the electrical outlet or the power strip.
    • 2
      Disconnect the USB connector cable for the printer from the computer.
    • 3
      Turn off your computer from the Windows "Start" menu or by pressing the "Power" button.
    • 4
      Plug the USB connector cable back into a USB port on the computer.
    • 5
      Plug the power cord for the printer back into power strip or electrical outlet.
    • 6
      Press the "Power" button to turn on the printer. Press the "Power" button to turn on your computer.
Oct 22, 2011 | Dell Photo 926 All-in-One Printer
Brand new brother HL-2140 get service call error (all lights flashing for more than 10 minutes). First time to setup. Don't know how to proceed.
You should have a manual with your new printer, please read it before doing anything with your printer. I'll try my best to show you how to set it up properly for the first time. Make sure to plug the right cable at the right place. There should be 2 basic cable for your printer to work properly; the power cord and the USB cord. Power cord is thicker than the USB cord (black). One end goes to the printer and the other to the power outlet. The USB cable is the data cable of your printer (white/transparent). One end should go to the printer and the other to the PC. First, plug the other end of the USB cable to the printer and the other end to the PC. Next, plug in the power cable to the printer going to the power outlet. Press the power button and you can now use the CD that came with the printer to install the driver. If the lights still persist, then check the toner and the tray. It should be properly fitted inside. Also check the paper, there could be a paper stuck inside.
Hope this helps . . .
Nov 08, 2009 | Brother HL 2140 Laser Printer
Is there a power cord other than the usb?
Yes, there definitely is either a power cord or a power adaptor unit for any printer.
The power delivered via USB socket can be enough for a pendrive, even a small external HDD, a mouse etc., but it's definitely not enough to run even a smallest printer.
Oct 25, 2009 | Office Equipment & Supplies
How to reset d5160
  1. If the printer is not off, press the Power button to turn it off.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the printer.
  4. Unplug the universal serial bus (USB) cable from the back of the printer, if connected.
  5. Wait 30 seconds, then plug the power cord back into the printer.
  6. Plug the power cord back into the wall outlet.
  7. Press the Power button to turn the printer on.
  8. Ensure that the memory card has been removed from the memory card slot.
  9. Make sure plain paper is loaded in the In Tray.
  10. Hold down the OK button and press the Right arrow button four times.
  11. If the test page prints, re-connect the USB cable to the printer.
Dec 07, 2007 | HP Photosmart D5160 InkJet Printer
Laptop wont recognize USB connection to turn printer on
Yes, you need a separate power cord, as this printer needs more power than a USB cable can provide. It should have come with this power cord, but if it didn't you will have to contact the store you purchased it from, or Canon directly, for the cable. If it only has 2 prongs, it's not using a standard PC power cable, so you need the specific one made for your printer.
Aug 28, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
