Question about Toshiba 2060 Copier
My company keeps their copier till it absolutely dies. The top lid/cover needs to be replaced. Where can I find this replacement part?
  • 1,110 Answers
Depending on what part is bad or broken, you can get your parts from precisionroller.com
Over to the upper right is a search box. Just put in toshiba 2060 platen cover and you will get the cover and the cushion. If you Hinge is broken which is more common just search for Toshiba 2060 Hinge and you will find those.
Good Luck and Thank You for using Fixya.
Posted on Sep 02, 2010
2004 Sebring 2.7 runs good till heats up then will die. like fuel starved. the oil light starts to come on at 1500rpms then runs rough and have to keep engine rpm high.
If you need to keep your rpm above 1500 to keep the oil light from coming on, you need to have that checked RIGHT NOW. When the light comes on, oil pressure is at an absolute minimum. Check the oil level in your crankcase, and top it up if necessary. If you still get the light coming on, you may have a bad oil pump, excessive wear on bearings, or a bad oil pressure switch. Get it checked out or you are liable to blow your engine.
Nov 27, 2016 | Cars & Trucks
I can not open the door on my Maytag top loading washer
Many new washer use a lid lock instead of a brake to keep people from reaching into the spinner before it stops. You probably have a
bad lid lock. Have a repair man open the top cover and repair or replace the lid lock.
Jul 06, 2016 | Maytag Washing Machines
There are usually two portions of the top lid to be removed to gain access to the motor compartment. Lift the top lid, squeeze the hinge to get the side into the frame of the hinge so it can release and allow them to come out. The same procedure should get the second lid removed. Now you should be at the second cover assembly, which is removed by releasing two, one on each side, snap clip tabs. They are located on the side of the 3rd cover, near the front corner. The corner needs to be lifted till the little tab snaps loose, then when both sides are loose this cover can be removed. Keep an eye out for screws that may need to be removed from time to time on some of the covers. They should be fairly self-evident when they're there. This should put you into the motor cavity so that you can lift the motor out , disconnect the wires and go check the motor.
Dec 12, 2013 | Kenmore Vacuums
My hp pavilion dv7 keeps running after the lid is closed
Change the settings in the Power section to shut-down when lid is closed. Power Settings, Advanced Settings, Change setting to shut-down when lid is closed.
Oct 29, 2012 | HP Pavillion Dv7-6165us 17.3" Amd...
INK CARTRIDGES ALL NEW. SAYING THEY ARE EMPTY
Hi, i think during the process of changing the cartridges, the top lid on the ink cartridge that clips or keys the cartridge down inside the printer has been broken and needs to be replaced.
I suggest you get a technician to help get a replacement for this. With this your printer should be in other.
Jan 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
Need a lid
After being asked to call a number of different phone numbers, I was finally able to order a lid for this from the company that manufacturers this slow cooker for Sears.
1-800-361-4639
$25.90, shipped to the US (the company is located in Canada) for the lid.
The part # is: 1003kj.
Note that the Sears model number for the slow cooker is KKC275.
The Sears item # is 68332 (even though the plate on the cooker and manual both say that the MODEL number is 68332).
Hope this helps,
Brian
Jul 18, 2009 | Rival 38601 Smart Pot 6-Quart
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid.
Geezer Geek
May 20, 2009 | HP DeskJet 6840 InkJet Printer
HP Printer top cover replacement
I think your best bet is just to store the old lid away and keep the receipt that HP sent with the new lid. That way you can prove they replaced the lid and you have the old one with the sn on it to prove it.
Dec 09, 2008 | HP LaserJet 4350 Printer
1997 bmw 328 convertible top deck lid strut replacement
NEED YOUR EMAIL TO SEND SOME IMAGES.
HERE ARE THE STEPS TO FOLLOW.
REPLACING LEFT AND RIGHT GAS STRUTS FOR SOFT TOP COMPARTMENT COVER :
  • Remove soft top compartment cover.
  • Lift soft top out of soft top compartment.
  • Lift gas strut out downwards, insert in available bore and lower the linkages.
  • Remove tab washer, raise gas strut upwards and lift out.
HOPE THIS HELPS
May 29, 2008 | 1997 BMW 328
Black replacement cartridge
This is an easy one, you do the black the same as each color cartridge. All four cartridges sit on a carousel that rotates.
Just keep pressing the button that's directly underneath the ready light until it says "rotating to black". After the machine stops rotating, open up the cover and put the black cartridge in.
Apr 03, 2008 | HP LaserJet 2840 Printer
47 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
