Hi i have just purchased an alba 32hdf tv i cannot seem to find the av button on the remote so i cannot play dvd or my games console could you help thanks
Benimur
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
ryan7
  • 11 Answers
SOURCE: Nothing works on remote
Hi, check out my (admittedly lengthy) fix here:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Hope it helps!
Ryan
Posted on Feb 12, 2008
samspelljr
  • 62 Answers
SOURCE: DVD CONNECTION
AV/TV Button
Press ¡° AV/TV¡± button,the will be some word show on the right top
of the screen, press ¡° PROG+/-¡± to select the AV source, and then
press ¡° VOL+/-¡±to enter AV mode. Hope This helps. If the dvd player is HD then it will probably be component 1 or 2.
Good Luck. Please rate me.
http://www.denver-electronics.com/UploadetFiles/154/25/DFT-1504_Black_English.pdf
This is the manual if you want or need it.
Posted on Jan 16, 2009
SOURCE: how can i put it on AV mode?
you will have to call the number on the back of the TV. There you can by a remote. I had the same problem.
Posted on Jan 25, 2009
SOURCE: finding AV channel without a remote control
get ewf 2004 on av channel without remote
Posted on Feb 19, 2009
I have a sylvanaia tv model srt2232x and I'm
Hi. Don't you have an AV button on you remote ? If your game is connected to an AV input, try to use the channel (-) buttons on your TV. Numbers below 1 mostly give access to AV1, 2 etc.
Make sure the AV input can work, simply by connecting a DVD player to it.
Oct 17, 2014 | Televison & Video
ALBA tv/dvd combi LCD26ADVD only plays in black and white and does not respond to the remote anymore since my toddler got hold of the remote, please help
Remove batteries and disconnect power to reset. If that fails go to settings and restore factory defaults. Alba should have web site to help.
Aug 06, 2012 | Televison & Video
I have a new slimline DVD and a sony bravia HD tv. My PS3 worked with the basis cable and I recently purchased an HDMI cable and now it won't work on any of my 6 AV channels, including 1 of the 2 HDMI...
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
My 32inch alba tv will not switch to av, to play dvd player. it does not switch to av viver remote controll. what could be the problem??
Hi
try removing all the scart leads apart from the one with the dvd. One of the other leads is holding ie forcing it to another source.( Or turn off the other equipment.)
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Cannot get AV on my Matsui 1407s
some TV's have a componant button which usally means AV
Sep 25, 2009 | Microsoft Xbox 360 Console
Game mode not working properly on sylvania tv
did you try to switch the tv modes Ex. my tv has av 1 av 2 comp 1 comp 2 does it have those modes
Apr 21, 2009 | Sylvania Electronics - Others
DVD CONNECTION
My tv has a "game" button and that is the only way my dvd will play on it. Hope this helps.
Jan 16, 2009 | Hisense LCD1504 15 in. Television
Phillips SRU7000 Universal Remote.
i have phillips universal remote that worked just fine until yesterday. my daughter and i were playing a video gae. since then i haven't be able to get remote to work. the little red light comes on up in the corner of the remote and thyere are brand new batteries. help!
al
May 16, 2008 | Philips Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
