Question about Brother LS-2125 Mechanical Sewing Machine
The thread bunches up under the material when i sew. thread then clogs up under the plate.
  • Anonymous Mar 30, 2014
    Thread all bunched up under
  • Brother Master
  • 7,365 Answers
First start with the needle & see if it's bent-roll the needle on a flat surface & see if it roll correctly
when a needle is blunt it makes a popping sound when it goes thru the fabric
check the bobbin to see if it's warped-I have had some that were
check to see if there is lint or loose thread in the bobbin case area
rethread the machine to make sure the upper thread is not catching on anything
sometimes the thread can come off the thread take up lever
& sometimes it can get caught on the spool pin & also on the notch that's on the thread spool it's self---I've had this happen before
if you sew alot-good maintenance practice is to clean the bobbin case area at least once a week-if you don't sew alot-once a month & also under the needle plate
when cleaning under the needle plate-make sure you do not damage the top of the screws when you remove them to clean under the needle plate & because if the top of screws get damaged they can pull the fabric when the fabric goes over them
check also to make sure your top tension is correct
Posted on Sep 02, 2010
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Bobbin thread bunches up under material
make sure that the bobbin carrier is fixed in properly
make the needle thread tension a lot tighter
Jun 23, 2016 | Sewing Machines
There is thread pieces under the tread plate and when the machine tries to trim the thread it doesn't and sounds like it's hitting something
Sewing Machine Thread Bunching Up? Here's Why! - Craftsy
www.craftsy.com > Blog Home > Sewing Blog
Jan 21, 2014 - There are lots of reasons for sewing machine thread bunching up, and ... or bird nesting, on the top of your fabric, the culprit has something to do ... Frequent dusting underneath the throat plate and along the thread .... It looks like it's hardly been used but the top thread keeps tangling below the material.
Sewing Machine Needle Not Catching Thread ' ThriftyFun
www.thriftyfun.com/tf80302359.tip.html
Dec 20, 2015 | Sewing Machines
Why is my thread birdnesting? i am getting some thread that bunches up under my fabric. I have played with the tension changed needles, and rethreaded both top and bottom
bunching up under the material is loose tension of the needle thread
pull the thread out before you thread the needle and if it doesn't require a small amount of effort to pull then the thread is not between the tension plates or the tension plates are not being allowed to move closer together to add the tension
check that the thread is actually between the plates and not to one side of them
full tension adjustment should make it fairly difficult to the thread by hand
Nov 20, 2015 | Sewing Machines
What adjustment can I make to my lower looper, thread does not stay under pressor foot while sewing
thread tension can be adjusted by the small screw that holds the spring plate on the bobbin carrier under which you have to pull the thread after the bobbin is placed in the carrier
a small movement is a lot of tension adjustment
if the thread is bunching up under the material ,that will be the needle thread tension and it needs to be tightened
Sep 28, 2015 | Sewing Machines
Thread to loose under the material
try changing the needle
adjust the top tenison one number or letter higher, using a scrap
piece of cloth to check the stitches till they look normal
clean under the needle plate and in the bobbin area for lint
Dec 02, 2012 | Sewing Machines
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
Thread bunching under work
Clean away all the thread.
If you look through the Singers at Relics.com you may find your machine and order a manual so you can be sure the bobbin has been threaded and is inserted correctly into the machine.
It is possible the timing has to be adjusted - you can find this at sewusa.com
Feb 22, 2010 | Singer 3116 Simple
Brother LS-2125 Mechanical Sewing Machine Logo
596 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
