Question about Lexmark X5470 All-In-One InkJet Printer
Trying to delete item in printing queue - Lexmark X5470 All-In-One InkJet Printer
  • 480 Answers
If you are having problems in deleting the printing queue, you can try to restart the print spooler service on your computer. also if that still doesn't work, you can re install the drivers for your printer.
to go to Print Spooler:
click on start/Pearl > go to Run/Start SEarch > then type 'services.msc' > a window will pop up > look for print spooler > double click to open > click on stop > wait for at least a minute then click on start > then close the window > then try to see if the print queue is still there > if it does, try to uninstall the drivers next and reinstall it agian.
Cheers!!
Posted on Sep 02, 2010
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
49.4C06 Service Error
This is a printer queue error. Go into your printer icon and select properties. You will see an item "check what's printing" click on this and it will take you to the print queue. Highlight each item and right click and delete.
Feb 27, 2013 | HP LaserJet 4650 Color Printer
Will not print. items in que.
In that case, if you've tried deleting the first item in the queue and it's saying "Error deleting the file". You need to reboot your computer in order to reset the items in queue and then print your document again. That probably will solve your problem.
Thumbs up me if this was helpful.
Regards,
-OmeL-
Mar 21, 2011 | Brother Office Equipment & Supplies
Cannot get printer to either delete item in queueor print it it says is deleting but does nothing whe ni switch off system completely and then switch on again does test page .. then nothing
Deleting an item in the print queue often doesn't seem to work until the system is restarted. I've had this problem with both XP and Win7.
The test page sounds like you have requested it. Try just cancelling a document, then when it hangs in the print queue, restart the computer.
I've researched several "fixes" but am convinced it is a Microsoft problem that they need to fix.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 17, 2010 | Computers & Internet
Document stuck in queue and will not delete or print.
Its a common problem. All you have to do is to restart the Print Spooler service and delete the print queue. To restart the service follow the steps: Open Control Panel > Administrative Tools > Services. Now find service named "Print Spooler" and right click over it and select "Restart" to restart the service.
Now open the "Printers and Faxes" folder and try to delete the print queue. Now you will be able to delete the print queue. If applicable you can follow the steps once again if any print queue refuse to get deleted.
Once the print queue is empty, you can print from your printer smoothly.
Cheers!
Apr 05, 2010 | Dell 926 All-In-One InkJet Printer
Item won't cancel out of print queue. How do I
I have run in to this more times then I would care to count. Unfortunately, what worked one time did not necessarily work on a different computer and sometimes even on the same one. If, after several reboots, the problem still exists, disconnect the printer from the computer. Try again and reboot one more time and try.
If that fails, make sure you have the cd with the drivers or go to HP's website and make sure they are available.
Delete the printer! Reboot 2 times.
At this point, the queue should be gone. Reinstall the printer, reattaching it when asked.
Aug 03, 2009 | HP Deskjet D1341 InkJet Printer
Can not print...jobs are held in queue
go to administrative tools THEN SELECT SERVICES. STOP THE PRINT SPOOLER SERVICE. then see if the item is still in the print queue.. if so delete it .. but I think it'll go away when you stop the service. when it does.. restart the print spooler
May 20, 2009 | HP Deskjet D4260 InkJet Printer
Lexmar Z611, How do I delete 20 items in printing queue?
Goto Start click on Run type in Services.Msc and hit ok.............. Now on that list select the one which says Print Spooler right click on it and click on Stop........ Now go to Run again type in Spool and Hit Ok............ on that window click on Printers....... Delete all the items under Printers............. Close that Window............. Now Right click on the Print Spooler and click on Start............. Now Uninstall the Software........... Download the Drivers from the website............Install the Downloaded drivers....... It Should work............ Thanku
Jan 12, 2009 | Lexmark X1150 All-In-One InkJet Printer
I had problem with dymo, so we printed receipt thru other printer and now got dymo fixed, so i tried to print, but it's not printing, i looked in printer que, there's some printing items that i cann't get...
right click the items in print queue and delete them. You have to wait a few secs before the print queue is clear. You can also try to reprint the same thing by right clicking the item in print queue.
Jan 02, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Lexmark X5470 All-In-One InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
