Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
I have a robinaire 34700Z. Sometimes while putting a car on a vaccuum the machine will **** all the oil out of the bottle on the side of the machine. when I go to charge, oil pukes out of the machine and puddles on the floor
    President:
  • 180 Answers
YOU NEED TO REBUILD OR CHANGE OIL DRAIN SOLENOIS
Posted on Sep 02, 2010
  • Jennifer Tomasic
    Jennifer Tomasic May 12, 2014
    Actually, you need to empty the oil drain bottle after every recovery.. the 2 tubes that go into the bottle will suck the oil up into the machine and will end up puddling down on the floor
How to drain the isv in ac34700z
To clean contaminated ISV of Robinair 34700Z, open front lower panel, then slowly disconnect 3 hoses from ISV (Liquid, Air purge and Vapor). Now unscrew ISV tank from machine and then fixed an adapter to Liquid port of the tank to allow all the contaminated refrigerant to go out from tank. after emptying the tank, if possible make vacuum for approx. 10 minute with an external vacuum pump. Replace everything its original location after completing vacuum. Now change spin-on filter (Located on the back side of the machine) and vacuum pump oil. Your machine is now ready to work.
Thanks and I hope this will help you to solve your problems.
Jun 24, 2014 | Robinair Cool Tech 34700Z Recovery,...
MY 34700Z ON RECOVER SAYS LOW PRESSURE, IT EVACUATES OK BUT SHOOTS OIL INTO OIL BOTTLE UNDER PRESSURE @ SAME TIME
your recycle solenoid is stuck open. the oil drain switch works by building pressure up to 16 psi then the recycel solenoid shuts off and the oil drain solenoid opens. if the recycle solenoid is stuck open you will get liquid 134 out when it is draining
Nov 19, 2012 | Robinair Cool Tech 34700Z Recovery,...
We have a robinair cooltech 34700z, looking for directions to change pump oil, can anyone help? thanks
For change vacuum pump oil follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL" then press "YES" key. Now vacuum pump will run for two minute & stop automatically. When pump stop you just open the oil drain cap and drain all used oil from pump (oil drain cap located outside of the machine near high & low side hose). After draining all used oil replace oil drain cap and fill 5 ounce new ROBINAIR vacuum pump oil then press "YES" key and keep filling oil up to middle of sight glass of vacuum pump. Press "STOP" key to complete the process.
NOTE: Do not over fill the pump & do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support
Hope this will help you. If so please vote for it. Good luck
Apr 08, 2011 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34700Z Recovery, Recycling, Recharging: when performing a/c system charging see bubles in ...
Pls Check oil drain solenoid it's may need to rebuild or replace.If solenoid is OK then you may need to change oil drain switch.
May 17, 2010 | Robinair Cool Tech 34700Z Recovery,...
When under vacuum down machine started pulling oil front injection bottle
You need to Change ''Oil inject" solenoin from small manifold assy.
Note:Green dot OR blue label denotes are oil injectoct solenoid.
May 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
Refigerant in oil recovery bottle
You have to change/rebuild oil drain solenoid & check oil drain check valve.
Sep 08, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
329 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
