Question about Refrigerators
Hello i purchased Samsung RL 34 ECSW , 2 days ago, after letting it stand for 4 hours after delivery, i turned it on, and let the fridge cool on maximum temperature for 3 hours, as i was directed, then i adjusted the temperature +7 in the fridge, and -14 in the freezer, it was showing above said temperature for 2 das and today it has changed to +3 and -20 by itself, what could be the reason?
  • 145 Answers
SOURCE: Sears Kenmore ColdSpot Frostfree Frosting up/Not working
You have a defrost problem. You need to determine which one of the parts is faulty. The defrost timer on that model should be behind the kick plate in the center front underneath. If you turn the little knob by hand you will hear a load click when it gets to the defrost point and the unit should shut off. Check in the bottom of the freezer to listen for water sizzleing or for water running down. If it is the timer is not advancing and needs replaced. If not you will have to take the back off the inside of the freezer to see if it is the heater or the defrost thermostat. Unhook power before taking panel off or replacing any parts.
Posted on Apr 24, 2008
SOURCE: temperature
I had the same problem and when we looked at the back the fan was running very slowly. We replaced the fan and that wasn't it. Then we replaced the board, bought it online for 80 bucks and sure enough that was it. Whirlpool was willing to pay for half of the part if I had once of there technicians come out. I think they know the boards are going on these. Mine is a year and half old. I have read several other sites with people having problems with the board. If the side is very hot, like ours was than this may be it. We just ran a portable fan to the condenser until we got the board in..hope this helps
Posted on Aug 12, 2008
  • 24 Answers
SOURCE: samsung fridge freezer model number
Hi just wondering if you figured out the problem with your Samsung fridge yet.
It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
Please let me know how you went with it.
Posted on Oct 26, 2008
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
SOURCE: Samsung cool n cool fridge
fridge is not getting cold freezer is ok
Posted on Jan 26, 2010
I have a RFG297ACRS (Canadian Model of AARS). Bought new and delivered yesterday. Waited 2 hours before plugging it in as directed by the delivery guys. Plugged in 24+ hours ago but until now it's still...
must be on demonstation mode, manual says the following: press ENERGY SAVER BUTTON AND FREEZER/HOLD 3 SEC FOR POWER FREEZER BUTTON simultaneously for 3 seconds until an alarm sound is heard.
Jan 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
I bought a Zanussi ZF4 fridge/freezer second hand about two weeks ago. When I installed it I made sure that it was left to stand for 12 hours before turning on and that it was cleaned thoroughly. The unit...
It is possible that it is the thermostat, and if not as you hear the compressor starting shortly then stopping, and redoing that many times.
Your compressor is certainly out of order and must be replaced by a professional, that means to dessolder the current compressor, and replace it with the new one, and change the gas.
So major intervention and at least 2 hours of work.
In the end, you will have a new heart for this great fridge.
Dec 03, 2009 | Zanussi ZF4 Top Freezer Refrigerator
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Frig not cooling
I had a same problem as what you described. I purchased mu Samsung RS2545SH side-by-side refridgerator from Costco 2 years ago. I contacted Sumsung, who then sent out a local/independently operated repair shop to come and perform the repair. After three trips by the repair shop and more than $400 in repair cost, the same problem persisted, and I'm stuck with a non-functional fridge for more than 2 weeks. Repeated calls to Samsung service line simply added more aggrevation and no results. The repair shop declared the fridge non-repairable, and my attempts to ask Samsung for a refund only get me a standard response: The executive review committee is reviewing your case!
Finally I simply had it, and hauled the fridge back to Costco, and thank goodness, the folks there were so kind and took back the broken fridge after 2 yrs from the purchase date. Thank you, Costco!
I do not recommend anyone to purchase a Samsung refridgerator. They may look nice on the outside, and maybe even a bit cheaper price. But you may very well be stuck with a non-working fridge in a year or two, and a warranty bureaucracy that will bog you down. And Samsung did not seem to care about standing behind their broken product. This will be the last Samsung product I will ever purchase.
Mar 22, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refridgerator is not cooling properly
Ours does this too; it says its 34 degrees but really its 53-58 degrees. . . The compressor coolant part of the machine freezes and then it can't circulate the cold air to cool the fridge. You have to unplug it for at least 24 hours to let it thaw, or you can take out the lower drawers and shelves, unscrew and remove the lower back pannel (from the inside of the fridge). We use a blow dryer to thaw out the ice block that formed on the unit. It goes faster if it is unplugged, this fridge is horrible we lost hundreds of dollars in groceries before we figured out the problem.
Dec 26, 2007 | Samsung Refrigerators
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
