Question about Microwave Ovens
I have a Kohler Fairfax K-12177. The faucet is leaking, major leak, out of the back of the body of the faucet. It appears that its leaking from a manufactured hole.
    Problem Solver:
  • 6 Answers
I have a Kohler kitchen faucet with the same problem. I called their customer service (1-800-456-4537) and they are sending a new valve and vacuum breaker free of charge.
Posted on Oct 29, 2010
WE HAVE A KOHLER #K7499-CPCB FAUCET AND THE WATER IS ONLY TRICKLING OUT. WHAT COULD BE THE CAUSE OF IT?
Check the aerator which is the screen on the tip of the faucet where the water comes out. You can unscrew the aerator and sometimes find calcium deposits clogging the screen.
Jun 23, 2011 | Microwave Ovens
Moen 7700 kitchen faucet leaks at base of spout
The cylinder which surrounds the bottom of the spout is part of the spout. The cylinder is sealed with o-rings at top and bottom. They probably need replaced. Feel free to use lubricant.
:o).
Jun 04, 2011 | Microwave Ovens
Moen 7600 kitchen faucet leaking from around handle
You will need to replace the cartridge....
here is tutorial on how to do that...
http://www.ehow.com/how_7241891_do-repair-moen-7600_.html
If you find that the cartridge will not come out you may have to purchase a Moen cartridge removal tool... you can get them at Lowe's or many othere plumbing supply houses....
http://www.bing.com/search?q=moen+cartridge+puller&form=HPDTDF&pc=HPDTDF&src=IE-SearchBox
heatman101
May 14, 2011 | Microwave Ovens
I have a moen 7637 single handle kitchen faucet that leaks around the stem. How do I take the lever off.
1) Use a small sharp-pointed knife and pop out the little plastic Moen logo at the bottom of the front side of the handle (and don't lose it!)
2) Lift the lever up a bit (the water may turn on) until you can see a small screw with an allen wrench socket.
3) Unscrew the allen-head screw; the handle will lift straight up.
Look down into the faucet; there's a philllips head screw. The leaking may simply be caused by this screw being loose.
May 01, 2011 | Microwave Ovens
We have a steadily dripping tap. Can you please help? thank you.
You don't say anything about what kind of faucet you have, so this may not apply. But if yours is the kind with handles you turn to control the water, you probably have worn-out compression washers. In this kind of faucet, water is shut off by pressing a rubber washer on the end of a threaded stem against an opening in the faucet body. When you turn the handle, you move the washer away from its seat and the water can flow. Over time the washer gets worn and no longer seals off the water. Also, the valve seat the washer presses against can wear and allow water to sneak past the seal. The result is that annoying drip or a steady trickle.
This site, among many others, shows how to change a washer and fix most drippy faucets. If you search for "repair a leaky faucet" you'll find lots of sites to pick from, including many with videos. If you faucet is not a compression type, a single-lever cartridge for instance, there are links to other repair procedures.
If your faucet is old and the parts very badly corroded and worn, you might want to fix the leak by replacing the entire stem as a unit. You can find replacement stems for most brands of faucet at big-box home improvement stores and at many hardware store. It's a little more expensive, but often much easier to unscrew the old one and pop in the new than to start trying to get the old washer off the stem.
A last tip: Whenever you do any work on a faucet, remove the aerator from the spout and run the water to help clear the line. If you just turn the water back on and run the faucet, debris that was kicked up during the repair can clog the aerator screen. Then you're left wondering why you get only a weak trickle or no water at all after you fixed the trouble.
Mar 10, 2011 | Microwave Ovens
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
I have a Franke faucet in my kitchen. (It has 3 levers - Hot, Pure and Cold). The faucet developed a slow leak. I tried to tighten the screws on all 3 levers and broke 1, so I have to replace it. To...
The cause of leaking is the ceramic gasket. Yes you can replaced it. Find your local hardware store then buy a repair kit for that faucet. If you can bring the sample bring it.
Please rate my help.
Thanks for using fixya.
Jan 10, 2011 | Microwave Ovens
I have a Moen 98043 kitchen sink faucet that is leaking water from the top, any ideas how to fix
Hi Adonish,
If you give Moen a call at 1-800-BUY-MOEN someone will be able to assist you and figure out what the problem is.
-Olivia
Jan 03, 2011 | Microwave Ovens
Kitchen faucet leaks from the base. Any suggestions?
there is a thing called plumbers putty you can try to use and seal it or you can take the pipe off and replace the seal if there is one.
Dec 04, 2010 | Microwave Ovens
Microwave Ovens Logo
701 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
