Question about Carrier 38CKC036 Air Conditioner
ON excessively hot days, the outside heat pupmp trips the circuit breaker. Most times it is only once, I turn the breaker to "on" and it works fine. Some days it pops two or three times. When the outside air gets cooler, it works fine. When the unit is operating, it appears to be operating normally (meaning cold air). I have not experience this during cold days.
  • 455 Answers
Hello I would add a HARD START KIT to the run capasitor (if there is not one already).This makes the compressor come on easy.If the breaker trips during running time the pressures are too high,hose off the condenser coil (fins).The unit might be slightly overcharged but I would be careful before adjusting the freon at all.
Posted on Sep 02, 2010
LGWHD1500ER 12 amp 15,000 btu Window a/c unit.
the condenser is in the hot sun and the fan that moves the air is not cooling or removing the heat from the condenser fins
This places the head pressure of the compressor too high and so the circuit breaker trips from the excessive current draw to run the compressor under this load
The answer to this problem is to place shade cloth on a frame which covers the air conditioner by placing it in a shady area
another solution is to replace it with a split system where the outside unit can be placed away from the sun
Jun 21, 2015 | Dryers
MY DOMETIC RUNS ALL DAY THEN IT BLOWS A BRAKER ONCE A DAY, WHATS THE PROBLEM ? BLOWS COLD AIR
Depending on how hot it is outside, there may not be a problem. It might just be running all day to try to keep up with the amount of heat that's outside. It'll blow a breaker most likely because it's drawing so many amps through the circuit breaker that it trips.
Jul 27, 2011 | Dometic 57915531 Air Conditioner
My breaker is conected to a hot tub. tub was working fine in auto mode. Turned on jets and breaker tripped. will not reset can you help me
I am assuming this is a GFCI circuit breaker? If it is it will have a "test" button on the breaker. When you say "jets" i'm assuming you mean when you turn on the blower to make the air bubbles? It could be you have a problem with the blower motor. When you start the blower, it trips the breaker. Be sure the blower is in off position when you reset the breaker. The most common fault though on a spa/hot tub is with the heater. If the element goes bad, and current flows to ground, it will trip the GFCI breaker. Again try and turn all functions off. Reset breaker, and then turn on one at a time till the breaker trips. First the pump, then the heat, then the blower.
Oct 06, 2010 | Square D Trilliant 40 Amp Circuit Breaker...
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
Domestic a/c runs fine for hours then trips circuit breaker
Check the difference between your incoming voltages at these times, it may be, if your plugged in to park power, the voltage getting to you may be less due to neighbors using more. If you have a genny, try using it when this happens and see if it trips. More lights, TV's etc are probably being used at night by others.
Jul 30, 2009 | Heating & Cooling
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
96 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
