Question about Cameras
Digital Lab photo Frame
Digital Labs Photo Frame Model K101 I have a flash drive with jpeg photos but the frame does not reconize it. Is there anyway to get rid of the default images? To clarify, there are a few images that seem to be "loaded" internally and I cant get rid of the darn things! HELP!!!!
  • 5 more comments
  • Russells95 Aug 27, 2008
    Default images interrupt SD card pictures automatically. Have to restart SD card. How do I remove default images?
  • Anonymous Dec 21, 2008
    You're not the only one with that issue! I called tech support and they said they won't call be back for 1 DAYS!!!
  • Anonymous Dec 23, 2008
    I have tried getting the frame to view my photos for the last three hours.  At first, it recognized the existing photos on my memory card that had recently been taken with my camera...When I erased those and tried to load an assortment of other existing ones that I saved from my laptop onto my memory card...the frame will not read any of the photos....ugh!!!  It is a gift for Christmas and they said that they will not return the call for one to two business days.  Ugh!
  • Jamielm Jan 01, 2009
    frame won't read .jpegs off of thumb drive. Only displays 'default' pictures that seem to be preloaded on the frame.
  • catsdeb Jan 09, 2009
    I tried to put pix from my computer on my digital photo frame, using a flash drive. They show up fine, but when I take out the flash drive they are not on the photo frame. The manual is no help at all. Does any one know how to fix this problem? Made by Digital Labs Modal K101 digital photo frame.
  • araszoo Jan 11, 2009
    We seem to be having the same problem trying to get rid of the default images. I hope some one can help.
  • Brenda Dickerson-Smith
    Brenda Dickerson-Smith Feb 18, 2009
    I am having the same problem with the default pictures preloaded into the frame. I have used every setting to change the view to a repeat mode. The pictures will play through for one time but then the screen reverts back to the default preloaded pictures. Has anyone figured out a way to get rid of these and change the setting so the pictures on a card will continuously play<
5 Suggested Answers
SOURCE: Digital Labs Digital Photo Frame K101
Go to Menu > Custom Setting > Repeat Mode > All
Posted on Oct 09, 2008
SOURCE: fuji finepix a900 Frame number full error
Hi!
In case you haven't sorted this out yet.
To fix this go into Menu ---> Setup. From there there's a Frame Number setting. It is normally set to: Continuous. The other option is: Renew which evidently simply resets the picture count. After selecting Renew the error message disappears and the camera works perfectly again.
Great little camera!
M
Posted on Jun 30, 2009
  • 244 Answers
SOURCE: What does Frame No Full mean?
If you look at the top right of your camera screen when reviewing pictures you should see the frame count. As yours is reading "Frame number full" the count should be reading 999.9999 so you need to reset to 100.0000. How to do this is posted in my tips section of my profile under "THE ONLY WAY I KNOW HOW" I have pasted the section below.
Cheers
FRAME NUMBER FULL!!
If you get this message on screen then your counter has reached 999-9999 and the camera will not take anymore pictures until you reset the counter to 100-0001.
To do this follow the instructions in your manual or read on my friends...
Firstly, make sure you have a picture card inserted into your camera and you have saved any pictures on it to your pc because you are about to format the card inside the camera and you will lose any pictures you have stored on there.
Ok. turn your camera on and press the menu/ok button and select "SETTINGS" from the menu.
Scroll through the menus until you find FORMAT. Select this and you will be asked if you would like to continue. Select OK.
Depending on how large your card is (16mb - 1,2 gb etc) will determine how long this will take but it's not very long.
After you have done this your card is now wiped clean of memory and has been formatted to be used for your cameras software.
Next, select FRAME in the SETTINGS menu and set your camera to RENEW and press OK.
Now come out of your menus and take a picture.
Review the picture taken and check the counter reading in the top right of the screen. It should now read 100-0001. The counter has now been reset.
Now go back into your menu and select SETTINGS again and scroll down to FRAME once again. Set this back to CONT (continuous) and press ok. Your camera should be reset and you can now use it.
Note: If you have more than one card you will have to reformat each card because the camera will store and recognise the frame numbers stored on the card and continue using them rather than set them to 100-0001 or will open a new folder on your card and start using this as the new one thus taking up more space on your card reducing the number of shots you can store on it
Posted on Sep 30, 2009
eagle338
  • 4889 Answers
SOURCE: I have an AKAI ADPF07X
What is the resolution of the photos? The max resolution of the frame is 480x360. So you may have to reduce the resolution of your images to be able to see them. Almost any image editing software can do this for you.
Posted on May 07, 2011
How do you add pictures to the photo fram:
Use PhotoFiltre free photo editor program to edit your pictures.
You may download it from the below link.
http://www.4shared.com/file/gqHN4jSz/pf-setup-en.html
1. Photos should be in .jpeg format.
2. It is better to scale your photos with the above editor to 800x600 pix.
3. Prepare your pictures in a PC using PhotoFiltre. Scale all the pictures.
4. Transfer your pictures from PC to a USB Flash Disk (Memory Bar)
5. Plug USB Flash Disk to your Photo Frame.
6. Probably your photo frame will ask to transfer your pictures from flash disk to internal memory. Accept this and by pressing enter/OK/Set (Any button that changes from one product to another.)
I think it helps.
Jun 15, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
Sep 20, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Can't get frame to read files on USB flash drive
keep the drive you use to 2g or 4g max.for some reason a lot of the cheap frames cannot handle anything bigger.
Mar 29, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Sep 01, 2008 | Cameras
Trutech digital photo frame
Most digital photo frames do not have internal memory and require external media to be plugged in permanently. Only the expensive ones have there own memory and usually not a lot.
Get an SD card and move your photos to it, that way you won't need to have the USB drive sticking out of the frame. That's if the frame has an SD slot.
Jan 14, 2008 | Electronics - Others
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Digital photo frame
hi, got the same problem, tried pics at different res, compressions, from different cameras and programs...still no luck
Dec 22, 2007 | Baby Gear
Cameras Logo
599 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
