Question about Samsung PCL545R 54" Rear Projection Television
Poor picture quality on my samsung HD TV
I am using a red,white and yellow cable instead of a red lue and green cable going into my cable box does that really matter?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey xf1racer,
Based on the description that you provided, it sounds like you are using a bundled composite video cable to connect your cable box and TV. Composite video cables generally consist of three color-coded cables: one yellow, one red and one white. While the yellow cable is typically used to transmit the video signal to your TV, the red and white cables transmit the right and left audio channels respectively.
Red/green/blue bundled cables however, are often referred to as component video cables - each of the three colored cables is used to transmit a different portion of the same video image from one device to another, and require a second separate cable (typically red/white) to transmit an audio signal.
The primary benefit of using component over composite cabling is that many users may report a cleaner, more brilliant image on their TV as a result. Please keep in mind however that this is not a guarantee that changing from your current set-up to component cables will improve the picture quality on your TV, as picture quality is often based as much on personal preference as it is the actual configuration and settings of the equipment used.
Additionally, many retailers may suggest changing your current configuration to one using HDMI cables instead to improve picture quality even further. Unlike composite and component cables, standard coaxial cables, and S-Video cables which transmit analog signals, HDMI cables are designed to instead transmit uncompressed digital signals. This typically means that more information is available for your TV to process in terms of color hue, color intensity, as well as image resolution. Again, remember that any perceived improvements will be based on both personal preference as well as your home theater configuration.
Should you have any questions or lingering doubts, I would strongly suggest speaking with a Magnolia Home Theater agent at your local Best Buy™ store for more information. Most stores will have similar TV's on display using more than one type of connection, and sales associates are always able to provide additional suggestions if desired.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 30, 2008
When hooking up HD Cable box I get "not supported
You most likely have to set the Cable Box to a specific resolution. Because that model only provides 720p/1080i, the box must be set to match that. You may need to use the yellow/white/red Composite output on the box to the tv first, so you can access the boxes menu and set it to 720p or 1080i, then I recommend using Component cables (Red/Blue/Green with white/red for audio) out of the box in to the TVs "Component 2" input. Now you should get a good HD picture. If you still can't get it to work, give me a reply with details and I will get back to you.
Jan 14, 2011 | Samsung HLN617W 61" Rear Projection HDTV
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
I turn on the Tv the sound comes on & the picture is blank Cablevision was here & said it's a problem in the set
He is probably not an expert (just kidding, of course he's not..) First, try connecting the Cablevision Box to another TV (if you don't have another HD TV, use the yellow/white/red Composite connection.) If there is still no picture, the box is no good. If there is, then try a different output from the Box or other inputs on the TV. Are you using HDMI (HD connection) out of your Box? Is the TV 720p or 1080p? Set the Box up (from the menu) according to the specs of your TV. Hope I helped.
Jan 11, 2011 | Samsung Televison & Video
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
NO volume
often people make the mistake of hooking their devices to the tv using more than one input.  a cable box for example may have many different types of outputs but you are only going to use one to the tv (preferrably the highest quality connection). try switching the inputs on the tv to see if you get the same picture on two different inputs.   If using s-video, you will also need a red & white RCA cable for audio.  The order of video cable quality from lowest to highest is this: Coax(screw on), Composite(yellow,red,white), S-video(Round)+(red,white), Component(video=red,green,blue), HDMI(carries HD video & sound)
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
How to change picture quality from 480 to 1080?
needs to be hooked to the tv with either an hdmi cable or componet(blue/green/red.yellow/white/) also check the game on the back of the box. some games are only made for 480 and 720
Jan 02, 2009 | Olevia LT37HV 37 in. HD-Ready LCD...
Have cable box ,also have vcr,and dvdplayer how to hook them all up
depends on what your tv is ill give u basic coax out from wall into cable box out from cable into vcr out from vcr into tv for better picture use red white and yellow from vcr to tv. for dvd use red white yellow out from dvd in to tv for better picture if tv has use s-video instead of yellow cable. for even better use red green blue(component)along with white and red for audio. if tv is hd and if dvd has it the very best is hdmi. you will only need one cable from dvd to tv instead of three or five sounds like a lot i know but take one step at a time youll get it
Sep 10, 2008 | Televison & Video
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Samsung PCL545R 54" Rear Projection Television Logo
102 people viewed this question
Henry  Thomas
Henry Thomas
