Question about Baby Gear
Rear brakes 2004 suzuki swift
Hi, I started to back and up the left rear wheel locked up, forward or reverse it would not release . i did get the drum turning but i can not get it off. I have pried and beat on the drum it will not come off. any thing else I can do, I don't have a set of torches so heat is out of the question.
thanks Josh
  • 2,039 Answers
You need to realease the ajustment all the way if you dont have torches and hit the drum with big hammer try to hit all over the drum not at the same place you might warp the drum thank you pierre
Posted on May 12, 2008
Daihatsu grand move manual
Your brake shoe may have failed and is getting wedged in your brake drum. I have had this happen to me.
Oct 01, 2017 | Cars & Trucks
Van will not back up or drive forward. Seems like the back end is locked up. Van started and shifted into gear, but would not move.
If you can feel the thump of the engine when you select gear I would say the trans is working, most likely I would say that your emergency brakes are locked, your rear shoes are binding with the drum. 2 causes, a frayed cable may not be allowing you to release the the brakes, or the springs are soft in the rear brake area and not releasing. Jack up the rear put in neutral, emergency lever off, see if wheel can turn by hand, if not, remove wheel hit brake drum with rubber mallet to see if this releases the shoes off the drum. Inspect emergency brake cable first to see that there is little tension holding it. let me know how you go. cheers.
Oct 14, 2013 | 2005 Dodge Grand Caravan
How to get the rear brake drum off a suzuki swift 2002
Make sure emergency brake is release.
If it still. There should be two hole about 3/16" to 1/4" diameter
on the drom surface. Use two 3" long bolt make sure it fit the hole's tread then screw in both hole enenly. It'll bring the drum out.
Or there is not hole. Then use rubber mullet (Rubber hammer) hit from the inside edge evenly (Or top/bottom). It should be able to come out.
Mai Lor
Feb 28, 2013 | Cars & Trucks
Left rear drum brake locks up and releases on my 04 dodge neon
need to check your emergency cable its probably stuck
Feb 21, 2013 | 2004 Dodge Neon
My 2002 mercury mountaineer have no problem going forward but it seen like when i put it in reverse the back wheel lock and it out out a funny smell
It sounds like you have a loose brake shoe inside one of your rear axle brake drums. You will have to remove the rear wheels and brake drums to find out for sure.
Dec 19, 2012 | 2002 Mercury Mountaineer
My '83 dodge ram van goes in reverse fine,but when i try to go forward, the R rear wheel spins, seems the L rear is jamming?? is this a diff or brake issue?
sometimes the emergency brake will stick even after it is released. Most drum brakes will still let it go backwards but not forward. I would pull the rear drums and check. If e/brake is stuck removing the left drum will be difficult. If so then you will have to manually adjust the brakes until drum loosens up. good luck
Jan 18, 2010 | 1983 Dodge Pickup
How do i remove the rear brake drums from a suzuki swift
1) With the vehicle jacked up and supported with axle stands, remove the rear wheels.
2) Using an old, thin, flat tip screwdriver and a hammer, remove the dust cap from the brake drum.
3) Using a 1/8" punch and hammer, tap out the lock nut indentation.
4) Using a 30mm, 1/2" drive socket and ratchet, unscrew the lock nut from the axle shaft.
5) Remove the flat washer from the axle shaft.
6) Ensure the hand brake is not applied.
7) Using a soft faced hammer, strike the outside edge of the drum repeatedly and all around while at the same time applying a pulling force on the drum. (This is best accomplished using two people and could take several minutes.) Be persistent!
8) Once the drum has been removed, tap or press out the wheel bearing from the inside out.
9) Clean and re-pack the wheel bearing with grease.
Good Luck!!
Thanks
Nov 18, 2009 | 2006 Suzuki Swift
Brake drum loose but wont come off
The representative icons are sometimes confusing on here. It is saying 1994 Suzuki Swift and you are saying 2,000 caravan.
I'm goin with you! ha...
Most vehicles that have drums on the rear have a slot (maybe plugged with a rubber or plastic plug) where when the plug is removed, a "star wheel" adjuster (used to spread the brake shoes) becomes accessible with a tool called a brake spoon. If you rotate the star wheel such that the brake shoe "Spread" is less, the drum should come off. And yes, it is probably the pads catching on a ridge. Getting the drums turned might be in order...
I hope this helps you. Good luck!
Sep 02, 2009 | 1994 Suzuki Swift
Brake issues.
OK! Front brakes not releases all the way; bad calipers or rotten insides on your flex lines (acting as a check valve holding some pressure). Rear- replace hardware and wheel cylinder,( make sure the smaller shoe is on the front halve of backing plate or it will catch and lockup.)
Nov 29, 2008 | 1986 Ford Ranger 2WD
Right rear wheel
remove back wheel and drum should come off sound like broken brake spings
Nov 18, 2008 | 2003 Dodge Neon
Baby Gear Logo
196 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
