Question about Hitachi P50H401 50 in. Plasma HDTV
I think someone poured water in my TV is there any chance on saving it?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
It's very possible. I guess I have been able to fix about half of them that I have worked on w/ water spilled inside. I would definately let a tech take a look and give you an estimate. It would be impossible to tell you which board the problem is on without checking it though. Does the set do anything at all now? Was the set playing when the water was spilled?
Posted on Sep 02, 2010
  • calaminedp Sep 02, 2010
    As far as I know the TV was just plugged in but not on. Right now it doesn't do anything. I was moving do to divorce and when I got it here I noticed a plate size water puddle on the screen as I had to lay it down to move it. I checked the vehicle and nothing was wet so I think the water is in the set.
Water is pouring out as fast as I can pour it in
Get someone to pour in the water and then you crawl underneath and look for the source of the leak. Take a strong flashlight.
Nov 13, 2015 | Cars & Trucks
I just bought a small crystal growing kit and the instructions are missing.
I had one as a Kid. Pour enough water to fill the jar about 3/4 into a pot and add powder. Heat till dissolved. Pour into jar and place rock in the bottom. The crystals should start to grow in about a week or less... good luck
Jan 11, 2012 | Toys
My 2002 duramax diesel is pouring water into the oil but its not even gettin up to the heads.. was wonderin if its the aluminum plate I have heard about that seperates the water from oil... it does have...
Must be in the intake, That is about the only place they can have a chance to get into the oil be sides you really need to check for water in your spark plugs, To see is the water is getting inside the valves. If not this is a enternal problem Good luck to you.
Apr 02, 2011 | 2002 GMC Sierra
Fuel in oil
as long as it wasn't started then yes it's ok even if it ran for a little while it still should be fine..good luck
Mar 31, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Dom lights go off and on while driving
Check your battery cables. Chances are they are loose or need to be cleaned. Your battery may be on its way out or your alternator.
If you see white stuff on the terminals and want to save money pour water and baking soda on the terminals. Foams up and cleans off the crud.
I would check the tension. Also your battery may need water in the cells. If those are low it can cause a battery to fail due to a bad cell.
If the alternator is the issue, then the battery works on its own and eventually dies.
You can always take it to a auto parts store and have it tested.
Sep 19, 2009 | 2000 Dodge Caravan
Water poured into the back of my tv. It's
you have to clean all the water corrosion off with rubbing alcohol and a toothbrush, then any blown or water damaged parts need to be replaced, you probably need a tv repairman.
Sep 17, 2009 | RCA 36V430T 36" TV
I pour coolant in from the radiator cap a almost instantly leaks
On most cars there is a weep hole that goes out when your water pump does. Chances are if your car was not making any terrible noises that it is just your waterpump.
Try cleaning the area then watching carefully to see where the fluid is coming out.But 9 times out of 10 its almost always the waterpump. If it was coming out of the oil pump then chances are that you will be able to see coolant on your oil dipstick and then thats a whole new set of problems.
Aug 19, 2009 | 1986 Isuzu Trooper
Water pouring out from under cherokee as fast as i pour in
you need to get it checked out by someone with mechanical knowledge as it may be a freeze plug or cracked pump housing, burst radiator, just try to see where the water is coming out if you can while you pour it in.
Nov 28, 2008 | 1990 Jeep Cherokee Limited
LG WFT1391TP TOP LOADER WASHER PROBLEM
use stick to hit the kids - the booklet will leave them with the feeling they haven't been punished
Dec 12, 2007 | LG WFT1071TP Top Load Washer
Hitachi P50H401 50 in. Plasma HDTV Logo
283 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
