Question about JVC AV-27530 27" TV
How do I turn On and Off Input 1 - JVC AV-27530 27" TV
  • JVC Master
  • 17,130 Answers
Use your Remote control to switch on AV1 and then to switch off either to choose a channel or press once again.
check and comment
Posted on Sep 02, 2010
  • mmartin827 Sep 02, 2010
    I have a S-Video I am using for Input 1 to my computer. All cables are good but when I go to press the Input button to switch it to Input 1 it says that Input 1 is turned "Off". When I press the Input button to go to Input 2 which I use for the DVD player it says Input 2 is turned "On". If there is a way to turn Input 1 "On" when I go to it so that I can view my computer on the TV screen that would be great. Isn't switching to AV1 the same as pressing the Input button on the remote? If not how do you switch on AV1 using the remote? The TV acts as though it doesn't recognize whats in Input 1
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
I am workimg on my 2000 nissan quest. it cranks and turns over but will not start. it is throwing codes P0340 twice and P0325. we replaced the distributor cap and rotor and still nothing. probably goi
P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor) -Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit (Bank 2) -Circuit Malfunction
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
P0335 Crankshaft Position Sensor -Circuit Malfunction
P0336 Crankshaft Position Sensor -Range/Performance
P0337 Crankshaft Position Sensor -Low Input
P0338 Crankshaft Position Sensor -High Input
P0339 Crankshaft Position Sensor -Intermittent
P0340 Camshaft Position Sensor A Circuit (Bank 1 or Single Sensor) -Circuit Malfunction
sorry would a play with this to know for sure ,check the wiring plugs onto the sensors to make sure their not full of oil or corroded
Aug 07, 2014 | 2000 Nissan Quest
When the television is turned on it will then turn off
You more than likely have the TV on the wrong input. If your source(cable,VCR,DVD) are on input one then you will have to change the TV input settings to input one, or two or video 1, HDMI 1...etc.
Oct 05, 2012 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I dont like t9 texting on my phone.... i turn it back to abc texting, but it keeps changing back to t9.... it getting aggravating to have to keep turning back on abc everytime i go to text sumeone...
1. From any text field, tap the arrow next to the input panel icon. Options... 2. Tap
Enter text tab, choose Input Method 3. From the an input method. 4. Tap .ok
Some of the input methods may not be supported according to the language.
You can also set options for some input methods
please rate this if useful it only takes 1 second!
Dec 20, 2010 | Samsung SGH-I200 Cell Phone
I have a 32 inch 3200 model proview tv and it went black screen turns on and off what could be wrong or do i need a new tv
1: be sure that you have selected the correct input on your tv, there should be a button on the remote saying "input" or "source" 2: be sure the source is turned on and that the wires coming from the source are in the "output" receptacles and that on the tv they are on "input" receptacles. 3: it may be possible that one input is damaged or malfuncioning, try switching to a different input (example: from "Video 1 to Video 2, or HDMI 1 to HDMI 2). check the contrast settings on your tv, it may be set so dark that you cannot see well
Aug 12, 2010 | Proview Televison & Video
I cannot watch cable TV on Input 1 when Input 2 is activated.
Tries to reset the tv Tuner board back to factory setting.By go into the tv menu.Go to PICTURE,go down to reset the Tuner board.All the HDMI ports should work now.Not,than the HDMI port 2 is shorted and dead,don't used the HDMI port 2.The tv should work fine,or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jun 16, 2010 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I have my satallite on hdmi input 1 and my x-box on hdmi input 4. If I turn the tv on and tv's on hdmi input 1 all 4 of my hdmi inputs show that input until I change the input for my x-box to hdmi input 4...
I have the exact same problem/symptom. I suspect this is a very common problem only folks just now discovering it as we buy new hdmi devices. I called technical support and got the "sorry, out of warranty" talk. Mr Badge #74754 claimed that this was not a known problem. Would love to hear if others having this problem.
Jan 01, 2010 | Vizio VM60P 60 in. Plasma TV
Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
Dec 19, 2009 | Computers & Internet
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
JVC AV-27530 27" TV Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
