Question about Ovens
The oven timer seems to have lost its volume. Can't get it back to normal volume even with pressing correct buttons. LPF9EGSS stove.
  • 17,130 Answers
You would have meant the gas control is not working .Best is to remove the valve and use a good jet of air to dispel off any dirt in the flow pipes.
If possible use a good antigrease spray to clean and wash off.
Use the control to either sides, left and right to complete the cleaning. Now it must control.
Posted on Sep 02, 2010
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Stoves 900 ef heritage doubel oven. I cannot seem to get the oven to work as my daughter has fiddled with the clock which has to twisting knobs - one saying cook time and the other saying start time. I...
For the 720ef , this is what you need to do. Hopefully this will translate to your 900.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
To reset the cook time, use the plus and minus buttons to set it to zero.
To cancel the automatic setting and return the oven to manual operation, press the COOK TIME and READY TIME buttons simultaneously.
I hope this helps.
Jul 28, 2011 | Stoves 720EF Electric Double Oven
How do i increase the volume on the alarm timer on my stoves cooker
From the handbook:--
Press the MINUS button to listen to the first tone.
Release the MINUS button and press it again to listen to the second tone.
Releasing the MINUS button after the tone has sounded will automatically select that tone.
Jun 14, 2011 | Stoves 720EF Electric Double Oven
I have a Stoves 900EM electric oven and want to change the timer sound. I have lost the manual and can't work out how to do this
If it is like my gas oven, press the - button until it beeps, without pressing the function button first. Then press - again and it will change each time. Stop when it makes a noise you like, or just pick the only audible one, which is the default.
Nov 19, 2010 | Stoves Premier 900EMa Electric Double Oven
I'm having trouble setting the oven to manual-pressing the cook time and the ready time simultaeously no longer seems to work
It could be that the contacts need some cleaning. Turn the power off and then repeatidly press the buttons. This action may will clean the contacts. If this doesn't work then a new timer from espares is about £80.
Nov 17, 2010 | Stoves 720EF Electric Double Oven
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
Lost handbook for cooker. Cant remember which
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Have lost the user manual and need to reset the clock and timer and would appreciate some advice on how to do this. The Stove is a heritage 720EM
Like most ovens you press the 2nd and 3rd buttons simultaneously (cook duration & finish time). While doing so, use + or - to set the time.
Aug 14, 2009 | Stoves Premier 720EMa Electric Double Oven
Volume on timer really quiet hotpoint forno
Pressing the "-" button on the control panel will cycle through the 3 or 4 available beep tones / volumes. No need to press any other buttons during or before this process.
Shame Hotpoint didn't see fit to put this in the manual. We dicovered it by mistake!
Jul 29, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
230 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
