Question about Galaxie Revell '65 Ford 500
When driveing it seems sluggish and the refs go past 4 before it changes
Our vw fox 1988 4 speed loses power whilst driving and doesn't want to ref up.What can be the problem.We've changed the petrol filter.
Check the fuel pressure at the injector rail. it looks like a air valve. You can usually borrow a tester from a auto parts store.
Aug 19, 2016 | Cars & Trucks
Veg drawer in lower part of frig frezzes the veg. setting on ref is 4
NEED TO CHANGE TEMPERTURE CONTROL IN UNIT. NOT CUTTING OFF SOON ENOUGH AND COLD AIR SINKS. ONLY A MATTER OF TIME AND OTHER THINGS WILL START FREEZING
Jan 15, 2013 | GE Refrigerators
My 2004 VW Jetta 1.8t 5-speed has developed a sluggish reaction when driving between 1500 and 2000 rpms. Once the car accelerates past this point the car drives fine with no other issues. This does not...
First thing to do is change the fuel filter, spark plug wires, spark plugs, and air filter. If this does not solve the problem then I would have the fuel injection system cleaned out and also change the oxygen sensor
May 28, 2010 | 2004 Volkswagen Jetta
Sloppy shifting on 2007 jeep liberty
i think you go to dealer to reprogram the transm. by original programmer
Jul 05, 2009 | 2007 Jeep Liberty Sport
Loss of power and drive but engine is still running
The water bubble under the dash might be a heater core, and the slow and sluggish might be caused by the transmission, try checking the wires and plugs, they may need to be replaced, we just changed out the wires and plugs on ours and it did wonders!
Jan 02, 2009 | 1990 Toyota Camry
Sluggish Transmission when cold
You need to change the transmission fluid and filter as soon as possible. Being sluggish when cold is a sign of a very clogged up filter.
Nov 09, 2008 | 2002 Kia Sedona
Motor Mounts?
the motor moun ts will not cause it to drive sluggish. Check your fuel filter and might be time for a tune up
Oct 08, 2008 | 1995 Jeep Cherokee
Truck seems to stall while driving.
I have a 1980 GMC 3/4 ton stick shift truck and this past week my truck seems like its stalling as it drives. i had the oil and fuel filter changed this past thursday and it keeps stalling.
Oct 04, 2008 | 2001 Ford Ranger Regular Cab
Galaxie Revell '65 Ford 500 Logo
64 people viewed this question
Top Galaxie Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Galaxie Toy Expert? Answer questions, earn points and help others
