Question about Haier Washing Machines
Error code Unb: After the last rinse finishes, spinning fails completely due to unbalanced of the laundry (What does this mean) and How do I clear the error. Machine does not spin the clothes.Every thing else is satisfactory. Machine: Haier "Automatic Drum Washing Machine. Model: HW-C1460TVEEME-U
I have had the same problem with the same model and rang up the help line to be told that the machine cannot sense the clothes in the drum. I tilted the machine forward and this worked for a while, sometimes i have to unplug at the wall so there is no electricity flowing through the machine for an hour and it resets itself,. Its not adequate but it works.
Posted on Jan 25, 2011
What does"ue " mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 29, 2011 | Samsung WF337AA Front Load Washer
What does "ue'"mean?
Jun 29, 2011 | Samsung Washing Machines
Error code "UE" clothes have
UE = Unbalance Error
Thanks for using FixYa !!
Dec 12, 2010 | Washing Machines
Neptune Front Load, Error Code, dc What does this mean?
The machine failed to reach a spin speed of at least 400 revolutions per minute (RPM) due to unbalanced load or motor related problem. Turn off the machine and redistribute the load properly. Add more load if the load is too small for the machine to spin but do not overload it. Let me know if the error code does not clear out for further troubleshooting and repair assistance. It will help if you can elaborate and provide more details about the problem including the exact model number of the mcahine.
Jan 25, 2010 | Maytag MAH8700A Front Load Washer
We get an e3 error message and we have no idea what that means. The machine will start but then at some point it simply stops. we have been able to use the rinse and spin cycles to get the water out of the...
It's an over load error. Don't put alot of laundry in the drum.
Copy and Paste from the service manual
- Motor overloaded due to too much laundry (Nonsensing)
- The motor hall sensor terminal is not connected.
- PBA fault
- The motor driving error from the PBA is weak.
: Unstable relay operation, etc.
This error
occurs when an
interference is
generated due
to too much
laundry, etc.
Dec 28, 2009 | Samsung WF337AA Front Load Washer
Unb after rinse cycle. What causes this error code and how can I prevent it from happening
Unb - Sounds like 'Unbalanced' - if there are too many clothes in the washer or you have heavy clothes on one side and light clothes on the other it might be tripping the balance switch. Try to even up the wash with similar clothes or lighter loads.
Dec 02, 2009 | Haier Washing Machines
Samsung frontloader problem
UE - UNBALANCE ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2009 | Washing Machines
Spinning but clothes are still very wet ,
unb means unbalanced i had the same problem and i called comet where i got it from and they replaced the chip board and ever since then its been fine i hope this helps you
Jan 27, 2009 | Haier XQG50-QF80 Front Load Washer
What does unb at end of wasn after it says end??
unbalanced - means it didnt spin properly due to clothes being unbalanced. Its supposed to stop the machine damaging itself - but its just a pain. Need to fill the machine with a full load to avoid this. Dont suppose your machine's a Haier??
Jan 03, 2009 | Washing Machines
HAIER HW-C1460TVEME-U
Err1 : Door not properly shut
Err2 : Drainage error (clean filter check hose
Err3 : temperature sensor short circuit
Err4 : Heater error
Err5 : water fails to meet specified level within 8 mins check tap, water pressure
Err6 : motor error
Err7 : motor error
Err8 : water exceeds protective level check circuit
End : end of wash cycle
Unb : after the last rinsing cycle finishes spinning fails completelt due to unbalance of the laundry
only reason I know is i looked through the manual after getting it myself could be something to do with running a bath while washer on or something perhaps not enough water getting in if powder channel blocked
Sep 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
773 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
