Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture My picture was going dark and as I tried to adjust the picture I must have darkened it more because the screen went black and now I can't see the menu screen to adjust the picture back so I can see it. Can anyone help me see something. Thanks, Bob
  • 58 Answers
You may have turned down the screen control
It is the lower one on the flyback transformer
Just advance it enough to get the pix back. If you advance it too much it may get retrace lines in the pix or shut down.
turn very slowly.
Thanks Guy
Posted on May 27, 2008
Canon S5IS picture darkens
I can't think of anything that is wrong in your camera. Must be a connection point in a switch that has a too high resistance. And even when you manage to find what switch, you could not replace it.
In the 7 years that your camera exists, camera's have become more sophisticated, and picture quality has increased even in the cheaper models, so perhaps it is worth thinking of a new camera? Perhaps you now even can buy a beginner DSLR, or a system camera, cheaper then your S5IS was 7 years ago.
Success
Feb 16, 2014 | Canon PowerShot S5 IS Digital Camera
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
I accidently sat some books on my calculator, and the screen went black...how do I make it go back to normal?
Adjust the contrast by pressing and holding the Diamond key and then tapping the - key to lighten or the + key to darken the screen.
Dec 07, 2009 | Texas Instruments TI-89 Calculator
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Dec 03, 2009 | Texas Instruments TI-86 Calculator
My screen is black and it wont go away how do i fix it?
The screen contrast of the TI83Plus/TI84Plus/TI84PLUS SE can be adjusted to suit the user. Sometimes after the batterie have been replaced the screen contrast is reset to the factory defaults.
To adjust it to your liking.
  1. Press the [2nd] key and release it.
  2. Press and hold the Down Arrow key to lighten the screen or the UP arrow to darken it.
In your case, the screen is too dark, so in step 2 above you press and hold the Down arrow until the screen lightens enough.
Hope it helps.
Nov 02, 2009 | Texas Instruments TI-84 Plus Calculator
Black screen
Try adjusting the contrast. It may be too dark. Turn the calculator on press the 2nd key and the down arrow. This is how to adjust the contrast and will lighten the screen. You can darken the screen the same way, but use the up arrow instead.
Aug 25, 2009 | Texas Instruments TI-86 Calculator
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Panasonic Rear Projection TV -dark picture
Javabean,
First off I think you meant Panasonic PT-51G44A which is an AP815 chassis. That unit has an all to common failure of the capacitor at C581 on the D board which is a 33uf/160v cap. Replace it and I think that will solve the problem..
Bill
Dec 11, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
