Question about Iwill P4ES Motherboard
Entered built in HDD1 user password
I HAVE A TOSHIBA SATELLITE WITH A LOCK BIOS. I WAS ABLE TO UNLOCK BIOS, BUT IN TURN THE COMPUTER IS ASKING ME FOR A BUILT-IN HDD1 USER PASSWORD. COULD YOU PLEASE HELP THANKS
    Genius:
  • 3,422 Answers
Just check out the below two links they will help you fix the problem.
CLICK HERE
CLICK HERE
Goodluck,
Please don't forget to rate the solution
Posted on May 10, 2008
  • 13,433 Answers
Hello
as the bios was reset the harddrive password was removed from the bios memory.
To get the password unlocked you will need to remove the harddrive from the laptop, buy a adapter so you can connect it to your pc and then do a few things Il tell you about later if your going to do it.
otherwice you can take the harddrive to a shop to be unlocked / reset to defaults.
  • 2 more comments
  • Ekse May 10, 2008
    with a shop I mean a PC repair center / shop with the required software and knowledge. NOT bestbuy, NOT wallmart. A real pc repair shop.
    but are you going to do this yourself?
  • Ekse May 10, 2008
    Windows/DOS unlock
    Note: This requires taking the laptop apart, which will void your warranty! - wont matter if you stole the laptop.
    1. Grab atapwd
    2. Create a bootable DOS floppy disk, and put atapwd.exe on it
    3. Remove the harddisk from your laptop and plug it into a standard PC, using a 3.5" => 2.5" IDE adapter
    4. Start up the pc with the bootdisk with atapwd in it
    5. start atapwd
    6. select the locked drive
    7. ... to be continued.
  • Ekse May 10, 2008
  • Ekse May 10, 2008
    you can also try this
    http://www.hddunlock.com/download/
I am being asked for my "Built-In HDD1 User Passward" for my TOSHIBA Satellite A135-S4527. Please tell me what it is, or how I can bypass it. I can reload my operating system, that is not a...
Toshiba Notebook PC's in the A105 series, and A135 series, suffered a lot of issues with asking for a HarDDrive password.
[ BIOS
Basic Input/Output System.
A small program contained in the BIOS chipset.
{Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
A Processor is an I.C.
Ram Memory uses I.C.'s on the sides. They are DRAM chips.
Just two examples of I.C.'s used in a personal computer }
When you power on your computer the first chipset to receive power is the BIOS chipset.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
{Simple explanation}
WinXP, and Win 7 are two examples of an O/S.
BIOS gave the harddrive in your laptop the moniker of HDD1.
If there was another harddrive installed also, it would be HDD2.
(HDD 1, HDD 2 ]
Reloading the O/S may, or May Not stop the request for the HDD1 password.
Most of the time? No.
Removing the CMOS battery (RTC Battery) will Not fix this issue.
{Real Time Clock}
It's a glitch in the BIOS program.
Toshiba is aware,
http://www.insidemylaptop.com/my-toshiba-laptop-displays-password-prompt-on-startup/
One solution (Besides Toshiba Support),
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
{ NOTE*
When you go to perform a BIOS update, make SURE the power will not go out.
If the power goes out during upgrading, you will wind up with an expensive doorstop, or an ornament for a table.
A battery backup device of some sort is recommended }
For additional questions, or comments, please post in a Comment.
(Believe upper right of your page. FixYa is constantly revamping in order to improve)
Regards,
joecoolvette
Sep 09, 2011 | Toshiba Satellite A135-S4527 Notebook
Hello, I recently had a Toshiba Sattelite L455 that suddenly promped for a BIOS password on startup. There was never a bios password set for this laptop. So I found a workaround using the onboard...
You hit the correct jumpers for this model to remove the motherboard bios lock, which shows you have done your homework well. Toshiba, like Dell set a bios lock and HDD lock on some laptops for security reasons, often when the cmos battery needs changing, it manifests itself.
As to why you got this request for a bios pass is very odd, if you did not change the cmos battery, however, removing the battery as you state would not fix the hard drive problem. The hard drive will remain locked and if, as I suspect, it is a security measure, you will not be able to remove it and externally access files or even format it by slaving it in another computer or docking station.
Your best solution would be to contact a Toshiba service centre and explain the problem and ask them for a bios unlock code. IF this was installed at the factory, they should be able to remove it (you WILL be asked to provide proof of ownership)
I have heard of some laptops being "time locked", which is where the time/ date settings in the bios trigger a request for a bios password for security purposes, but never actually seen this occur. This might explain why the bios pass request appeared randomly as it did. There is the possibility that this was caused by a virus, although, again, I've never heard of this happening.
Jul 24, 2011 | Toshiba Satellite L455S5980 Notebook
Hdd1/ssd1 password
I have bought a used toshiba satellite L555D-S7006 with windows 7 home premium 64 bit with the amd processor, it was working great. Well the other day I turned it on and it said to enter the bios password, I never put a bios password into the computer. I did some research on this and took the motherboard over to a freinds and he removed the cmos battery, after i reinstalled the motherboard now its asking for a HDD1/SSD1 password. So does anybody have any ideas about how to fixx this problem
Sep 24, 2010 | Toshiba Satellite L455S5980 Notebook
My computer says wen i turn it on enter built-in HDD1 password it is a toshiba A200 laptop anyone that can help email me please thanks craighowarth58@yahoo.co.uk cheers people
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
Sep 18, 2010 | Toshiba Satellite Pro 6000 and 6100 14.1...
I need to reset, bypass, or remove the HDD1 PW
Shutdown The System
Press ESC and Power button together
Enter the passwords if prompted
Press F1 to enter the BIOS
Select the password field (it shows Registered)
enter bkspc or space
enter your existing password
press enter
It prompts for New password
Just enter
Repeat for verify
Now password is Unregistered
If you found this post helpful , please rate it!
Regards
1234s282
Apr 17, 2010 | Toshiba Satellite X205 Notebook
I sent it back to toshiba to fix a bios password issue. I got it back and now it asks for a hdd1 password. Any ideas.
It sounds like you have change the password jumper setting on the motherboard. I searched toshiba and found information on how to fix your problem. Let me know if this helped or if you need more help. Please rate me mysleuth
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Satellite+A135-S4487+password&x=12&y=8
Apr 28, 2009 | Computers & Internet
Toshiba 300 forgotten password for HDD1 and 2 in bios settings
hi,
there is only one way to get the passwords call toshiba tech support.
Further Queries are welcome
Mar 28, 2009 | Toshiba Satellite Pro L300 Notebook
Can I reset the HDD1 user password on Toshiba satellite?
If the password was set on the hard disk from the laptop that it was install on, then you can reset or remove the hard drive password using the BIOS configuration, you need to enter the existing hard drive password to this.
There are no back door paswords available, if you ca't remove the password then the drive is useless. This protection is use to prevent unauthorized access to data stored on the hard drive.
To get the laptop operational again you need to replace the hard drive and install Windows again.
FixYa is a free service and advice is given freely by its members but for some services there is a charge.
Mar 08, 2009 | Toshiba Satellite A135-S4527 Notebook
HELP
If the BIOS and the Hard Drive are locked, it's not something you should be attempting yourself. Toshiba would be the people to approach, at one of their dealerships. If the laptop is still under warranty they should unlock it for free, if not there will be a charge. You will also need to prove ownership of the laptop before they can proceed, so remember to take that documentation with you.
May 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Iwill P4ES Motherboard Logo
3,251 people viewed this question
Top Iwill Computers & Internet Experts
Alun Cox
David
David
Willem.
Willem.
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
