Question about Maytag Atlantis MAV6000 Top Load Washer
I have a 6 yr old maytag top loader washer that does not wash or spin. It filled up with water and then stopped working. The power light is on but it does nothing . Any suggestions?
    President:
  • 2,501 Answers
There is plainly no drive to the drum, it could be a broken drive belt or a dead motor.
Is there any humming from the motor?
If all is silent it could be the motor has died. If there is any sign that the motor is turning, then the drive belt could be gone.
Remove the back and look at the drive.
Alternatively the driver circuit board may need replacement.
Posted on Sep 02, 2010
Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
Mar 23, 2015 | Maytag Washing Machines
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Maytag Performa top loader stopped spinning
GO TO www.repairclinic.com ENTER YOUR MODEL NUMBER AND SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 THEN LOOK FOR PART NUMBER 1042142 THIS MAY BE THE PROBLEM. IT SAYS A WORN BEARING WILL CAUSE SLOW OR NO SPIN. YOU MAY HAVE NOT NOTICED SLOW SPIN TILL NOW BUT I'D SAY CHANGE THAT AND YOU SHOULD BE GOD AGAIN GOOD LUCK
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
