Question about Coleman Powermate Powermate 5000W Generator
Starts but will not keep running - Coleman Powermate Powermate 5000W Generator
  • 90 Answers
Sounds like you are getting enough gas tostart but not run. check the carberator bowl to see if it has gas in it. make sure your valve to supply gas from the tank is wide open. blow your fuel line back with low air pressure. it is possible you float is stuck up not letting gas flow into the bowl. remember, spark, fuel in, exhaust out. good luck
Posted on Sep 02, 2010
Would an alternator make your car will not start
If your battery is fully charged, the car can start and run from the battery with no alternator at all. It might run 1/2 hr with no alternator.
A good test for the alternator is to start the car and then unhook one of the battery terminals. If the alternator is good, the car will keep on running without the battery. If the car turns off hen you disconnect a terminal, then the alternator isn't working.
But a bad alternator won't stop your car from starting...it will just not keep your battery charged or keep the motor running once the battery gets less than 12V
Feb 24, 2015 | Cars & Trucks
Outboard starts but won't keep running
If you keep sqeezing the fuel bulb, will it keep running? If it runs then fuel pump problem. Also check for a clogged fuel filter.
Jan 04, 2015 | Boating
Need s step by step start up.New owner of old machine 5521bbc
put machine in neutral pull the chock all the way out put throttle full open push in brake pedel all the way turn your key switch to start it if it hasnt run in a long time probably need to rebuild the carb if donsnt start try sqiurting some starting in the carb if it starts and dies it means carberator needs rebuilt you try to star it again this time before it dies keep it running with starting fluid just shoot short squirts in carb to keep it running do this for only 2 minutes if you keep doing it you will damage motor try that and see if it will run
Sep 15, 2014 | Garden
My washing machine keeps burning out the capacitor
Does your machine have a start cap. and a run cap? It could be that the run cap is failing because the start cap is not engaging. The purpose of a start cap. is to provide the additional boost to get the motor turning, it then drops out and the run cap. takes over to keep the motor turning. Run caps. typically are not big enough to start the motor and will fail over a period of time.
Nov 09, 2013 | Whirlpool Washing Machines
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
Check rotor slip rings for cleanliness, brushes, stator resistance, rotor resistance. Then replace control board if they check out.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
My remote start, starts my vehicle but won't keep it running?
You will need the dealer to scan the system for faults in the remote starting system which i assume is factory installed not aftermarket junk.
Oct 20, 2012 | 2006 Cadillac Escalade
Trouble starting keeps running after turning it off
If it is chugging and running rough after you turn the key off, it may be "dieseling" which is caused by carbon buildup in the cylinders and the idle speed being higher than spec. Pulling the coil wire from the coil and the engine continues to run is a good example.
Aug 26, 2012 | 1991 Ford Ranger Supercab
Tyies to Start
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 02, 2010 | Haier 65-Pint Dehumidifier
Coleman Powermate Powermate 5000W Generator Logo
128 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
