Question about Fujitsu LifeBook A6025/C Notebook
Don't let me down load programs and give me error memory full
  • 95 Answers
Hi sunny9951762,
Your Hard drive is already full try to remove some programs
Hope this helps
Thx
Banaple
Posted on Sep 02, 2010
Put in another HD made it a slave but i dont see it as a slave in system files
The master/slave drive model applies to IDE drives (older) these use a 40 or 80 pin ribbon cable. The newer SATA drives (L shaped connectors) don't rely on master/slave config. If you are using IDE you will need to specifically configure the jumper on the main drive as master and the other as slave, alternately you can set them both to cable select. The slave drive will show up under disk management as Disk 1. If you add a second disk this will give you more storage space, in this case 50GB (think of this a long term storage or data that is saved after the computer is shut down) Ram on the other hand is where the computer stores data and applications for faster access, not all of a program has to be loaded in to ram, parts of it can be swapped out from your hard drive as needed. Having more ram means the computer doesn't need to waste time swapping out parts of a program, it can load it all into ram at once.
Feb 03, 2012 | Computers & Internet
I don;t have microsoft office on my computer!
You can buy the program from any of the computer stores or on line from Microsoft web site. OR You can down load the same from MS Office site by paying the necessary payment.
Please note that it is not free.
My sincere advice is to buy the program on CD then to down load it . There can be errors/corruptions while down loading where as with CD nothing can go wrong and it is available to you at later stage if anything goes wrong.
Dec 09, 2010 | Microsoft Office Professional 2007 Full...
What do you mean by this error? "The instruction at 0x003bfc61 refferd memory at 0x305eff8 the memory could not be written".
most likely it is a software error, as the pc is shutting all of the running programs down to turn off the PC, that is where the error comes in, you could try to stop some of the background programs to try to figure out exactly what app it is refering to. It will probably not harm anything unless it is a program like word or something and you haven't saved the document, if that can't be written before the PC shuts down, you would lose your work. If it is a memory issue with the actual RAM, you can run a memory test in windows under all programs Administrative Tools, or in the control panel under Administative Tools, and then Memory Diagnostics, to check the hardware,
Please give a fixya if this helps or solves your problem
May 15, 2009 | Computers & Internet
Getting Out of Memory message
reseat the memory card or the hard drie is full
May 02, 2009 | Computers & Internet
Error code 105 for casio te-2200
Hi.
We can check the memory allocation.
Turn key to program mode.
5 SUBTOTAL SUBTOTAL (must press subtotal twice).
This will print memory allocation.
Look down the printout and tell me what figures are listed under file numbers 16 and 40.
Mark
Jan 04, 2009 | Casio Parts Cash Register PC Desktop
My laptop is very slow why
Try downloading CCleaner after installing it run the program and clean the registry also make sure to go to the tools>startup and see how many programs are being loaded when your PC starts up. I will bet you will have a lot of updater programs and **** that is loading and running on your PC slowing it down. I fyou come across a process that is loading on startup that you do not know what it is google it. Google will tell you what it is and if it is necessary. CClener is recommended by PC world magazine and it is a very good program. Give it a try and let me know how it works.
Dec 03, 2008 | Computers & Internet
Referenced memory error in photoshop elements 6
Was it the preferences file that you deleted? The description you gave to your problem sounds like your running a windows machine instead of Mac so i'll give you keys for PC. While program is launching hold down the following keys "Control+Shift+Alt" then when there is a screen that asks to delete the prefs files select "yes".
Nov 16, 2008 | Adobe Photoshop 7.0 for PC
Memory Error Messages
It could be either one of them. It is hard to tell without actually having the computer here. This may sound crazy but make sure your hard drive is not full. Windows uses a swap file that grows each time your computer is powered up and then deleted when powered down. If your hard drive is getting full it has been known to generate memory errors especially when using memory intense programs such as excel and programs like photoshop. Do a system cleanup and defrag your hard drive. Hope these suggestions work!
Dec 04, 2007 | Computers & Internet
Problem with sending a text message
hello alexann, Your phone is out of ram memory. Symbian phones use the internal memory as rom memory (dinamically allocated) ram memory (for user programs) and firmware storage. If the internal memory is almost full the phone will begin to give you such errors because it can't load into ram the text aplication that is require to start in order to process sms messages. Please try to avoid to fill the internal memory and instead move anything from it to the memory card. A full internal memory can result in slow phone operation, errors, program crashes or even the failure to boot-up (start) the phone. Therefore, in your case you should try to free more internal memory (phone memory) and check the sms folder to see if you can send messages. If this doesn't solve, you may have a virus or a bad program installation that corrupted symbian OS's registry. This will require to hard reset the phone. Please come back with a reply if these methods fail. Good luck!
Jun 06, 2007 | Nokia 3230
Fujitsu LifeBook A6025/C Notebook Logo
32 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
