Question about Compaq FS7600 17" Flat Glass Monitor
Discoloration on monitor
A week ago my monitor FS7600 are being blue things that are black. When I select from the menu of my monitor settings magnetism or configuration of the magnet, the image is distorted leaving all colors but again lose the contrast and what is supposed to be black stays blue. At first my brother arranged with the move a bit but the monitor is no longer fixes and I do not know that I can do. Thanks for any help you can give me. PS: It looks like being in the photo that I send.
  • thinkfirst Sep 01, 2008
    My monitor only shows the colors blue, yellow and black. It is extemely annoying. Please help me. I have a Compaq FS7600. Is it worth fixing or should I just buy a new monitor.
  • 558 Answers
Bad vga cable in the monitor
Posted on May 10, 2008
How to change red blue and green color on monitor hp7540
Press the menu button on the monitor, should be the far left button...use the minus and plus buttons to scroll thru the menu. Select the function you want by pressing the far right button (not the power). The function you want is the one witht the temp icon and the letter "K". press the far right buttion again and use the the plus and minus buttons to adjust the level.
Hope that helps.
Tom Miller
Broadcast Engineering
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
I have an HP7540 monitor that I need to be able to change red, blue and green colors on thru the menu
I hope you know how to enter and navigate through the OSD (On-Screen Display) menu of your monitor.
Enter the menu and navigate to 'Color' menu.
Under that select 'User'.
Now you can select either Red, Green or Blue.
After selecting a color it can be increased or decreased.
Press Exit button to go back, select the next color and set it to your liking.
Monitor flashing black lines fs7600
It's time to responsibly recycle any CRT monitor,
and either find a friend who has a CRT monitor that is gathering dust, and offer to take it off their hands, or to spend $50 (or $100) to buy a used (or new) 17" LCD monitor.
Aug 01, 2010 | HP Compaq FS7600 17" CRT Monitor
Monitor fs740 contrast is 0%, can't adjust it.
in your monitor settings you should have a default settings selection button you can Select and it will or should set your monitor to default . If it doesn't work , you have a problem with the monitor itself .
May 12, 2010 | Compaq FS7600 17" Flat Glass Monitor
How to close the small blue monitor control window that pops up unexpectedly? Escape does not work, the cursor disappears behind the window. Compaq model FS7600
From what I can gather from the "help" files on the hp website when the display comes up (presuming you are referring to the control display) then you need to use the buttons on the front of your monitor to exit it.
Button 1 launches the control display
Button 2 moves backwards (left) through options
Button 3 moves forwards (right) through options
Button 4 is the "select" button
Button 5 is the power button.
When the display comes up, you need to use buttons 2 or 3 to get to the "Exit" label on the display. Then press button 4 to select this.
The user guide for this model is here
Nov 10, 2009 | HP Compaq FS7600 17" CRT Monitor
My monitor does not display any color other than blue.
Check monitor button to select proper colours or reset it to factory settings
Sep 08, 2009 | Gateway FPD1775W Monitor
Compaq FS7600 Streched Screen
I'm no genius, but your problem sounds like you can go to the menu icon with the two horizontal arrows and adjust it. Like i said, I'm not a genius, so it might not be your problem.
Jan 28, 2009 | Compaq FS7600 17" Flat Glass Monitor
The monitor is not in focus and there is nothing to select in the menu to fix it.
It's Internal setting req to adjest LOT focus control
check CRT base(Focussing Grid)If u find any fongus Pl replace CRT base
Some times CRT and LOT problem also
Sep 29, 2008 | Compaq FS7600 17" Flat Glass Monitor
Compaq Monitor Model 7600
Dear Lilrose: Here's how to dim your FS7600 monitor. Press
"menu" on the front of your monitor. Now press + button until
the icon just to the very right of the 12 0 clock position is
highlighted. Now press select. A graph will appear and by
pressing the minus button the screen should start to darken.
When you are satisfied, push the menu button to escape.
Hope this helps.
Radial
Jun 19, 2008 | HP Compaq FS7600 17" CRT Monitor
Compaq FS7600 17" Flat Glass Monitor Logo
137 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
