Question about Garden
I cannot pull the cord to start the motor... - Garden
    President:
  • 1,545 Answers
Remove the top cover and then just remove the starter/recoil unit itself for inspection to identify what the culprit is...it will need to be removed. If it works OK after its removed or during removal, turn the flywheel by hand to make sure the engine isn't locked up and look underneath where the blade is and make sure nothing is stuck under there also. Sounds crazy, but stuff happens.
Posted on Sep 02, 2010
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
Pull cord wont spin the motor
The engagement "dog" is probably rusted in place. Try spraying WD 40 on the recoil mechanism as you pull the starter cord
Jun 27, 2012 | Garden
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
Gary
May 19, 2011 | Garden
Crank pull cord doesn't pull out on honda pressure washer.. The machine is only 3 months old
if the fuel tap has been left on it may have fuel on top of the cylinder and would not able to pull cord.
if so take the spark plug out and turn over,fuel may come out of hole.replace spark plug and try to start. if it still won't turn over,you will need to take the face plate off the motor. remove and inspect if there is any foreign objects. try to turn motor over by hand., grab on to fly wheel & turn. if it moves freely it may be the pull start it-self. try pulling the cord out. if no problem assemble and try to start.
Dec 02, 2010 | Honda Pressure Washer PSI 3000
Pull cord stuck to motor housing
Ok You have to release the engine brake. BY pulling down the bail to the handle as if you were going to start the engine. Hope that helps.
Oct 21, 2009 | Garden
My Kenmore Progressive vacumn motor turns off and on while vacumning. I don't know if I should take it for repair, purchase a new one or find someone who can do easy repairs (family member).
Turn on the vacuum but don't move it--just start at the plug end of the cord, bend and pull gently on the cord, but hold the plug in the socket. Work along the cord while listening to the motor for cutoff. When you get to the internal break in the cord, any bending or pulling will immediately start and stop the motor. If this occurs near either end of the cord, it can be cut off shorter and a replacement plug put on (if on that end). If it is the vacuum end, the machine needs to be disassembled part way to reattach the cord. If the break is near the center of the cord, just replace the entire cord. Good luck!
Aug 04, 2009 | Vacuums
Gasoline trimmer won't start
This is a problem with the pull start clutch, remove the four screws that attach the pull cord mechanism to the motor, detach motor, remove the pull start clutch assembly, lubricate, clean and reinstall, You should be back to trimming asap.
Jul 05, 2009 | Garden
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
May 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
