Question about Meridian Two-Line Corded Business phone
Some one has changed the pass code on my phone system and now I can not pick up my messages
  • John Pearson Sep 03, 2010
    when I tried your solution. It comes up saying locked. Does that mean the I have to get the phone company in or is there another trick
    John Pearson
  • 2,069 Answers
You could try to reset the passcode by pressing feature 983
the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys. press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
your password will be reset to 0000
press the next key till you see the ext/name info.(about the second or third "next"
press the CHNG key and enter in your first and last name
the # key advances you one space press it twice to enter in the comma between the first and last name.
press the Rls key when finished
Posted on Sep 02, 2010
  • 6,993 Answers
in this case, you have to reset the phone in other to clear off the pass code.
Since you did not state the make and model of your phone, then you might have to check the user manual of your phone in order to learn how to reset the phone or clear off the code.
Good luck.
Posted on Sep 08, 2010
  • Walesarumi
    Walesarumi Sep 08, 2010
    I just saw your comment now after sending my first post.
    I don't think there is any other trick if the first solution didn't work. The best thing to do is to contact the phone company. By so doing, the problem will definitely be solved, I am very sure of that.
    You can just go ahead and contact the phone company.
    Take care.
NEC DT700 series message: SIP Server Not Found
The phone is not being routed to the SV8000 Series SIP server. You could try to reset the phone to default in case it is holding a previous setup and attempt to allow it to pick up the new settings. While the phone is searching for DHCP press Hold, transfer, *,# The display should show ADMIN Put in the password 6633222 (Admin default) You should gain access to to the phone system Press 3 then Press 3 to access factory default. Ok that and the phone will preform a memory wipe. It should then do a restart and try to pick up the settings. If you cant access Admin (Have they changed the PW?) or it doesn't work then the phone needs deleting and resetting from the SV8000 series server, the ports for Voip need passing through the firewall or your phone needs to join a VLAN. None of these things you can do if you don't have access to these systems or the knowledge to program.
Nov 23, 2012 | Lands Phones
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 | Cell Phones
Retreving calls from another phone uaing my code does not work any longer. I would like to reset the code. Please give instructions. Thank You,
Changing the Remote Access Code The Remote Access Code is preset to 500. You can change the Remote Access Code to any three-digit number from 500-999. DO NOT pick the same number as that assigned to the Priority Calling Code. 1 Press g. The Message Window displays CH. 2 Hold down c for at least two seconds. The system announces "First digit." 3 Press / or ? to change the digit. 4 When the Message Window displays the desired first digit, press c. The system announces "Second digit." 5 Press / or ? to change the digit. 6 When the Message Window displays the desired second digit, press c. The system announces "Third digit." 7 Press / or ? to change the digit. 8 When the Message Window displays the desired third digit, press c. The system announces the new Remote Access Code.
Aug 26, 2011 | AT&T 1725 Answering Machine
Uniden Dect1560 - For incoming calls it only rings 3 times. Is there a way to make it ring 6 times before it goes to voice mail?
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Jul 24, 2011 | Uniden Cordless Phone
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
I have voicemail through my telephone company. Recently my panasonic phone system kxt7731 has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left...
I have voicemail through my telephone company. Recently my SAMSUNG SGH-D980 phone system has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left messages that I cannot retrieve! I would like to "turn off" the voicemail function of my phone system. I'm not sure why the phone changed from working "properly" to now picking up voicemail calls. Thank you for any help you can give me!
Sep 14, 2009 | Cell Phones
Trying to change number of rings before voicemail picks up
This is done in station administration. F config side of the system. Do you have access to system programming?
Jul 21, 2009 | NorStar T7316 Corded Phone
Need to set password
To keep your voicemail messages secure most vendors keep this is an administrator function or at least a technician level change, you will need to contact your system admin or your Phone vendor to reset your pass-code.
Mar 13, 2009 | Mitel 5220 IP Phone
Need to change welcome message
you should be able to log on to the vm system when it ask for the mail box you enter 99# and pass word 1234 or 123456 or the mail box could be 0 then # and pass word 1234 or 123456 .once you get in press 9 and press what ever number that goes to the auto attendent .
Feb 23, 2009 | Lucent PARTNER18 Corded Phone
Pick up calls from another location
Manual - http://support.radioshack.com/support_phones/doc65/65505.pdf
SECURITY CODE
To use your system from a remote telephone, you must first enter
a 3-digit remote operation security code. The security code
label is located on the bottom of the system. Enter the security
code after the system answers and sounds two tones. Within 7
seconds, enter one of the remote commands
OPERATING THE SYSTEM FROM A
REMOTE LOCATION
Dial your phone number. Even if the system is off, it will turn on
and answer after about 10 rings. After the system sounds a
tone, enter your remote operation security code. Enter a remote
command (see “Remote Commands” on Page 19). When you
finish, press 5# to end remote access.
REMOTE COMMANDS
Note: When listening to messages in remote mode, there is a
pause during playback every 2 minutes and 40 seconds. Press
0–9, #, or * to continue playing the message.
Press To
1# Play new messages.
2# Play all messages.
3# Delete the current message.
4# Repeat a previous message.
5# Stop and exit.
6# Skip a message.
7# Turn on/off the system.
8# Record an outgoing message.
9# Record a memo.
0# Monitor the room.
Hope this Helps... Have A Nice Day... :)
Nov 01, 2008 | Radio Shack 3808 Digital Answering Machine
Meridian Two-Line Corded Business phone Logo
Top Meridian Lands Phones Experts
george  peters
george peters
Are you a Meridian Lands Phone Expert? Answer questions, earn points and help others
