Question about CTX Value VL 510 15" CRT Monitor
Set up pv505 monitor to computor do i use both power dc in and display in put ports
  • CTX Master
  • 32,281 Answers
Yes you do, connect the mains power to the monitor and the video cable from the monitor to the video port on the computer.
Posted on Sep 02, 2010
I have ac Acer S202HL LCd monitor. When I booted up one day it didnt come on.
first check with your both power supply out put is coming 19 Volts dc.
if its not coming check with multi meter primary and secondary of your adopter continuity.if no continuity replace with proper working adopter.
Nov 07, 2013 | Acer S202HL LCD Monitor
Aple HD Cinema Display 23" is dead, no front LED light or back display light
Contact Apple support by phone 1 (800) 204-4427 US toll-free or chat, set up a repair, or make a Genius Bar appointment for iPhone, iPad Apple Mac Technical Support Phone Number 1 800 204 4427
Jun 14, 2017 | Apple Cinema Display 23" HD Monitor
The orange charge light comes on but when I press to start computor nothing happens no green light, the orange light flickers a few times.....I have taken out hard drive and batteries afew time but nothing...
Charger faulty or Motherboard problem.
You can check the power supply of the charger by measuring the DC voltage at the DC jack with a multimeter set to DC volts (red probe on the inner of the jack, black probe on the outer of the jack, should measure 18-20 volts.
Also check the security of the jack in the DC port, make sure it is not loose
See if the Ac adaptor has a green led on it, flashing LED indicates power not being "used " by the laptop
Gut instinct with this being a compaq is that the fault lies in the motherboard
Jan 12, 2011 | Compaq Evo N610C Notebook
No post and no display
Do you have any indicator light activity at all?
If so, then try hooking up an external monitor.
If it shows display on the screen this would point to video issues (CCFL tube, Inverter, video chip, one or a combination of.)
There is also a key combination to switch between internal display and external monitor. Usually FN key + (little monitor symbol on one of the upper function keys)
If you dont have any indicator light activity then;
Things i would try first.
  1. Check the power adapter for power. (if you have a voltmeter this would be the easiest way) if not, try switching to another outlet
  2. Check your DC power jack to see if there is any freeplay or damage to it.
  3. If both these check out, then i would unplug dc power adapter from laptop, remove battery, and let the laptop sit for a few minutes. Then hold down the power button for 10-15 seconds. Plug in the DC power jack but dont place the battery back in yet.
  4. Try powering up. if no go, then plug the DC power jack back in and try powering up again.
If this still doesnt work, and your DC adapter voltage checks good and your DC power jack isnt loose, i would suspect either a charging circuit issue or deeper motherboard related issues.
Hope this helps
Feb 15, 2010 | Gateway MX6750 PC Notebook
I have a viewsonic computor monitor...I was hook up to 2 monitors..When I unplug one I cannot get a signal from the one left...check all plugs and wires
Things to try.
Move the signal (VGA) cord going to the monitor from the computer, from the one output, onto the other output.
If you removed the primary monitor without changing your display settings, then your second monitor will have nothing to extend from.
Another possibility is that the second display is disabled since there is no monitor detected.
Also, Be shure the power cord plugged into the back of the monitor, is pushed in all the way. These tend to slip out a little when getting moved around.
Hope this helps.
Dec 11, 2009 | Computers & Internet
Screen blank
Sounds like its simply going into power save mode. Does your screen come back on when you move the mouse or press a key on the keyboard? Is the computer still on? Check your power options in control panel.
Nov 29, 2008 | Computers & Internet
Multiple display problem
Hello. Your driver software was 71.6MB large. It not only included the driver software but secondary software for you to control & setup dual monitors. The package came with a HDMI connector which is used to connect the HDMI femal port to VGA port, if the monitor does not have a HDMI male port. Currently the reason you can not see your display is because the signal comming out of the video card is set to the other port on the card. Once you switch to the other port you'll have display on your monitor. Open control panel, than open display. Display Properties will open on your desktop. Click settings than click advanced. You should see another tab that reads something like, NVIDIA® nView Multi-Display Technology. (I'm guessing because I only use ATI's software) I can't load your driver software on my current system. The two cards may be different but the software is similar. This Nvidia tab is where you set up your monitor or monitors. Once in this advanced portion for your video card you can set which connector from the video card will display on what monitor. There will also be a ton of settings you can adjust, from color to 3D & other options. You must have an icon by your clock as well that allows you to open the standard display properties or the advanced display properties.
Feb 19, 2008 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
Downloading
Use the USB ports that are on the back f the PC, not the front ones or the one on the keyboard, these are low power USB ports. You can also purchase a powered hub that supplies its own power. The maximum draw on 1 USB port is 500ma, shared across all devicesattached to that port including non powered hubs. My USB PC-cam took 450 all by itself!
Feb 14, 2008 | Photography
Power button won't turn off monitor
Well, I noticed this after I installed win xp sp3. My monitor won't turn offwhen I click the button. I have to set my power setting to a certain timeframe then require a relogin but the monitor just won't turn off otherwise.
Oct 23, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
CTX Value VL 510 15" CRT Monitor Logo
26 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
