Question about Lexmark X2470 All-In-One InkJet Printer
Lost instructions need instructions for brother dcp110c cartridge #1 what holes match what colors
  • markeit May 13, 2008
    thanks
    Champion:
  • 207 Answers
The colours on my brother dcp110c dont print out the colour i have chosen on screen. i.e. whichever yellow I choose it prints out green and the other colours are the wrong shade. anyone know how I can sort...
When an inkjet printer stops printing the right colors, it's because one of the colored inks are not coming through properly.
To clear this up, you'll want to run a couple cleaning cycles.
Press the "ink" button on the DCO-110C
Press the "set" button twice and then start
You will now get a print out which is supposed to have 4 blocks of colors.
Follow the on screen instructions to go through the cleaning.
You can repeat the cleaning up to 5 times, anything more is a waste of ink.
If the color does not clear up at all after 5 cleanings you need to either bring the printer to a technician or replace it.
Thanks,
Pat
Mar 29, 2010 | Brother DCP-110C All-In-One InkJet Printer
My brother printer not working well
Are you using Genunine Cartridges!!!!
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
Instructions on color fill holes. For HP 1350 xi all in one
this printer uses a HP 57 color cartridge. INSTRUCTIONS are : 1) place a paper towel over surface you will work on. 2) get disposable hand gloves , 3) remove carefully the top label of cartridge (do it slowly to avoid tearing) put it aside , your going to need it to put it back. 4) with the electrical golden dots strip side facing you , the top LEFT side hole is CYAN color , RIGHT side hole is YELLOW , and middle hole (close to you) is MAGENTA . Push the FILLING TUBE about halfway down into the cartridge, be careful not to damage the ink chamber at the bottom of cartridge. squeeze bottle (tube) in a slowly manner until the chamber is full . hope this helps AJ
May 03, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printing not complete
you may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Refill instruction
Trust me, this is the BEST way and the EASIEST way to refill black and color LC61 or LC65 inkjet cartridge from Brother. See the pictures
1. cut the plastic part (see picture). You can use a utility knife or a steak knife (very easy to do)
2. make a hole on the left side (NOT in the midle) and do it straight and don't go deep (see picture)
3. poor the ink with your refill kit and do it straight and don't go deep because the inner side of the cartrigde is made of cheap plastic (like a plastic bag) and you don't want to perforate it
4. put your plug, tape, hot glue or what ever you have to seal the hole.
5. put the cartrigde back in your printer, do a print test and this is it.fa55e1c.jpga111867.jpg
Jan 01, 2009 | Office Equipment & Supplies
I have changed inks keeps saying low on inks yellow empty wont print
tape up the side thats the outside theres a black bit inside just cover it up that will do it
Oct 25, 2008 | Brother DCP-110C All-In-One InkJet Printer
Not printing
i have a brother mfc 5440cn printer,error message says out of black ink,i replaced it,still says out of ink,i opened and checked micro switch,then bypassed micro switch,still reads out of black ink and wont go any further than that
Sep 29, 2008 | Brother MFC-5440CN All-In-One InkJet...
Lost instructions
I also have lost the instructions to this refill kit. Where do I drill the hole?
Feb 27, 2008 | Nukote Nu-kote RF196 Black Refill Kit
Brother 210C One colour cartridge empty, want to print a black and white fax
Yes, if you dont need the color anymore in future:
You can cheat with empty c/y/m carts by sticking some dark but very thin adhesive tape around the nose (see picture).
After that the printer logic expects the c/y/m carts always as full.
But you cant print any colors within the next 2 weeks anymore because air will dry out the print head (and destroy the color nozzels)!
See brother homepage for instructions on how to print in grayscale only!
Jan 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP110C Instalation Disc
download software + driver package from brother homepage of your country
Oct 27, 2007 | Brother DCP-110C All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
