Question about Jwin JBTH710 Bluetooth Headset
Need corde to pair - Jwin JBTH710 Bluetooth Headset
    President:
  • 1,932 Answers
Pairing code is'0000'(four zero)
Thank You
Posted on Sep 02, 2010
My lenovo keyboard is not working.i have three blinking lights above number lock
Is it a corded or non corded keyboard. Possible problems with non-corded: Dead Battery, no link to USB receiver(dongle) on computer, bad USB receiver (Dongle) on computer. From Lenovo Website:
Keyboard and Dongle Paring:
Auxiliary tools: PC with Windows XP or Windows 7, two AAA cells
Pairing steps:
1. Insert Dongle into PC. Be sure that the Dongle is recognized by PC and the distance between keyboard and the Dongle is within 10cm.
2. Press down F2, F3 and F4 at the same time, install cells, release F2, F3 and F4 and then Press "3" to begin pairing. After finishing pairing, press "Windows" key to check whether the pairing is successful. If "Windows" key works, it means that the pairing is successful; otherwise, the pairing fails.
That was all I could find on the site.
Sep 22, 2014 | Lenovo Keyboard
What is the proper pairing procedure?
When you're attempting to pair them, are they physically attached to your PS3 using the charging cord? Whenever I paired a headset, I'd plug the charging cord into the headset and into the PS3 and then turn on the PS3.
Sep 17, 2014 | Sony Playstation 3 (PS3) Console
Bose Soundlink Mini paired to Win 7 PC but will not play audio
For pairing your bluetooth Bose speaker to your computer you might need to update the Bose speaker software
I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord.
SoundLink Wireless Mobile speaker update
Aug 24, 2014 | Bose Corp Bose SoundLink Mini
Why no dialing tone
no dialing tone indicates an open line or an extension that has not been hung up properly. IF you have a corded phone then it may be in the cord (broken at the hand piece or at the base) On the technical side it may be from the wires in are not paired properly ( go google and check for phone line pairing) and on the financial side the account has not been paid
Jul 06, 2014 | British Telecom BT BIG Button Corded Phone
What cord do I need to hook subwoofer up
You need the power cord that should already be attached, plus a single RCA patch cord to connect to your source. You could use just one of a typical RCA pair, if that's all you have.
Nov 18, 2013 | Sony SA-WMSP1 Subwoofer Speaker
Need manual for wiring phones
The 612 system required 3 pairs per phone. Every 3 pairs on the 25 pair cable would be one station. A modern 6 conductor jack would be wired according to the label. If you have jacks with Green,Red,Black,Yellow,White, and Blue wires, then it's wired as follows.
W/Bl - Green
Bl/W - Red
W/Or - Black
Or/W - Yellow
W/Gr - White
Gr/W - Blue
Oct 12, 2012 | Inter-Tel (660.7600) Corded Phone
I puchased one kx t 7565 x ph for my panasonic epbx it is not working what can i do i verified the epbx box one line the voltage is low
Let me see. A 7565 is an analog system phone, it requires 2 pairs to operate, and you'll see 24 volts on the inner pair and about 13 volts on the outer or data pair. You can plug the phone directly into the KSU jack, making sure you have a 4-pin base cord. Outside of that, I have no idea what "low voltage" is.
Carl
Mar 31, 2011 | Panasonic KX-T7565 Corded Telephone
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
Need to replace the pull cord assembly, because something that tension the spring is missing. Tried substitute cord but found after reassembly there was no tention on the cord something is missing.
When the cord breaks, the internal spring will completely unwind. You have to re-tension the spring, then attach the cord and wind it onto the spool while holding the spool against tension. Finally, feed the end of the cord out through the cord port and tie the handle while still holding tension. A small pair of Vise Grip pliers will hold the cord while dealing with the handle. It's about like setting a trap without getting your fingers caught. Hope this helps!
Jun 07, 2010 | Craftsman sears 18" Chain Saw Chain (...
Downloading pics from razr to laptop
you need to get motorola phone tools in order to transfer.
Jan 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Jwin JBTH710 Bluetooth Headset Logo
111 people viewed this question
Top Jwin Radio Communications Experts
Michael Vincent Cruz
Are you a Jwin Radio Communication Expert? Answer questions, earn points and help others
