Question about JVC AV-65WP74 Rear Projection Television
Video Inputs not working
I just changed out the convergance mods, once I have the board back in, had a great pic but no sound. In getting the sound back up, all of a sudden, the video inputs, all 4 do not work now. It was working fine initially. Is there a specific wire/board/chip which all inputs lead into? The three in the back and the one in the front? Is it maybe a setting on the menu feature of the remote? Thanks for any help you can provide.
  • JVC Master
  • 8,617 Answers
Did you have the back of the tv open while the poer plug was plugged into the wall? If so the set will need some serious repairs as that model has a safety feature where if the back cover is removed without removing the plug from the wall it wipes out all the digital and video circuits. You have to defeat the safety feature before removing the back panel, and if you plug it in even for a second with the back removed the damage is done.
Posted on May 28, 2008
The screen wont come up but the sound will
try connecting your av inputs and outputs connect the yellow wire to your tv where it has all its inputs/outputs and your problem should be solved
Nov 30, 2009 | Microsoft Xbox 360 Console
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
Samsung HCL5515W...when using coax input pic convergence is off, red and blue seem off....when I use the component inputs it constantly flickers between the squigly lines and picture with convergence off?...
on component your device may have to be on progressive. old dvd players you could switch back and forth on progressive and normal. the squigly lines sound like you need to make sure its on progressive. hook it up using the yellow video slot on player and tv (any cable will work). go into menu and look for progressive and change it on.
Jul 14, 2009 | Samsung HCL5515W 55" Rear Projection...
Using monster
Hi, You will need to go into the menu of the AVR to change a few settings. To get into the menu -
  1. Make sure you are on an input of the TV that is connected to the COMPONENT VIDEO output of the AVR (I imagine you already have this hooked up)
  2. Using the Denon remote that came with the 1907, filp it to the back side and open the door that covers more buttons.
  3. Press the System Setup button
  4. Go into the AUDIO SETUP
  5. Make sure the DIGITAL INPUT ASSIGNED is set to none for the audio input you wish to use for the PS3.
  6. Going back a menu to VIDEO SETUP, make sure that the COMPONENT VIDEO you are using is assigned to the AUDIO INPUT you are using.
That should fix your problem. If you need more clarification or this did not work feel free to post that on this question. Good Luck
Jul 07, 2009 | Denon AVR-1907 Receiver
Sony KP46WT510 picture goes back and fortto horizontal color bars
The pictures show the result of a bad terminal input board. You can verify this by checking the inputs. Connect devices to the board and try different inputs. You will most likely find this problem on the tuner and component input were your DVI and composite video will be ok. If it is the same on all inputs replace the A board
Jun 24, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Mistubishi Convergence/video display problem
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 26, 2008 | RCA P56923BL 56" Rear Projection...
also check resistor values on the chips and resolder the tuner as this can cause problems as they heat up , then replace any electrolitic capacitors in the video circuts selector ic
i will be back to see what you get
electech
Oct 26, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Conv problems with no pic has sound
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Apr 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Composite and s-video inputs stopped working
You may have shifted the input board a little while replaceing the IC's. Double check every plug and connector, not just by visuale inspection, but by going and removing and replacing every connector. I have had problems like this in the pasy and have learned the hard way, everything is not as it looks. Good Luck
Jun 04, 2007 | Philips 60PP9202 60" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
51 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
