The clock on my Fujitsu Siemens Scalio L computer loses time.How can i fix it?
    Scholar:
  • 91 Answers
Try this link to Fujitsu's website in order to download the PDF service manual for your computer. I didn't have a serial number so I could not get you specific info for your computer. Let me know if I can help you if this doesn't work.
http://www.fujitsu-siemens.com/support/manuals.html
It sounds like it is the system battery or CMOS battery. You may need to replace this.
Posted on May 10, 2008
    Sergeant:
    Champion:
  • 271 Answers
There is a small cell battery which keeps some data like TIME running and CMOS settings saved...even if the computer is whiched off...Your battery is weak now...replace it with a new one...
Where can you find the CMOS battery for Fujitsu Siemens Amilo PI3625
On the web!
Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie - YouTube
? 6:39
www.youtube.com/watch?v=s8kKHChQ2sw
Oct 16, 2013 - Uploaded by MrHarsel Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie ... Fujitsu-Siemens Amilo Pa 3553 - Disassembly and fan cleaning - Duration: 16:09. by ...
Sep 25, 2015 | Fujitsu Computers & Internet
I have a fujitsu siemens AMILO Pro v8210 ,hardisk derial nr.871100490181 0807. Every time ill switch it on it ask for SATA HDD PASSWORD.wHAT IS THIS AND WHERE CAN I GET...
Problem 1:
The hard drive has been encrypted and password protected for theft protection. SATA HDD passwords cannot be reset or circumvented, if the person who entered the code does not tell it to you, the hard drive must be replaced for a new one. Again, there is no remedy. Connecting the HDD to a different computer and formatting the drive won't work either.
Problem 2:
Siemens and Fujitsu divorced some time ago, but Fujitsu continues to support the joint venture customers. An authorized Fujitsu service station can remove the BIOS password, but you will need to show proof of ownership.
Find contact information HERE.
Dec 23, 2010 | Fujitsu Siemens Computers & Internet
Hi, laptop will not start
Seems like your Operation System crashed. Find your reinstall CDs and reload windows.
If you find someone who can pull the hard drive and hook it to another machine and run a check disk that might save you from reloading it and losing all your data.
Apr 15, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have an e2010 fujitsu lifebook. When I turn the computer on, it says windows didn't start properly and wants me to select safe or last known good and so on...however none of them will work. The computer...
Insert your Windows install CD and boot from it. When it asks you to select either install a new copy or Repair current OS. Select current OS, you might lose some data but it might fix the starting problem.
Mar 14, 2010 | Fujitsu Siemens LifeBook E2010 Notebook
Can i upgrade my ram to ddr3 if so what would you recomend .cheers
Thank you for the clarification sir.
NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
This is the support page for the Fujitsu Scalio 600 Media Center,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
Uses either DDR Sdram at 333MegaHertz, or 400MHz.
(PC2700 and PC3200 respectively)
DDR Sdram has 184 gold plated contact pins on the bottom.
DDR2 Sdram has 240 gold plated contact pins on the bottom.
DDR3 Sdram has the same amount of contact pins as DDR2.
The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
Nov 18, 2009 | Televison & Video
Restore factory settings on a fujitsu siemens amillo pro
You should be able to fix this simply by inserting the original Cd that came with the computer and following the onscreen instructions.
Or the startup disks (if created) when you first used your laptop.
Alternatively If you do not have the one that came with your computer then you should be able to purchase one from ebay quite easily, and then insert it and follow the onscreen instructions.
I hope this helps you, Chris
Nov 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu-Siemens computer problem
Check power options...How to:- go to control panel and type power in the right hand box ie search control panel then change power options...
Oct 31, 2017 | Fujitsu Siemens SCALEO C772 17" CRT...
Amilo pro 2030v faan
We did not find any results for Fujitsu > AMILO Pro V1000 (FAP:GBR-147150-H01 ) needing a fan for my laptop computer. Other searches you may want to try: Related searches Click on the Link above, Good Luck.........Please dont for get to Vote, Thank You.
Dec 15, 2007 | Fujitsu AMILO Pro V1000 Notebook
Laptop Clock loses time
This is a sure sign that your CMOS battery needs replacing, but you may need to take to a qualified repairer as the battery can be hard to access or even locate.
Dec 16, 2006 | Fujitsu AMILO D-7820 Notebook
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
