Question about Mtd Garden
Brand new machine Starts no problem on cold start setting but when moved to run it cuts out. Followed instructions to the letter! Help please
  • 1,040 Answers
Sounds like you have bad gas or the carburetor needs adjusted a little bit.
Jim
Posted on Sep 09, 2010
  • Jim Parker
    Jim Parker Sep 13, 2010
    Do you need more help?
    Jim
Cutter not working
Hi Jackie, I'm Julie, what brand and model of sewing machine are you using, please?
Aug 05, 2015 | Sewing Machines
Refrigerator stopped blowing out cold air and fridge and freezer defrosted. All electricity is on and it is blowing air but not cold enough. Set to coldest setting. Ideas?
more than likely the relay on the compressor went out which is a very common problem with all whirlpool brand refrigerators. If you get behind the machine while it is running and take the back cover off you'll more than likely hear a humming sound followed by a click. You have two options as far as repair goes, you can either order the overload relay from a parts distributor, like marcone or apd, or change it with a hard start relay kit. I would personally go the first route since its plug and play, meaning you would pull the old one off and put the new one on without cutting any wires.
Feb 16, 2011 | KitchenAid Architect KBRA20EMSS Bottom...
I have a Victa Tornado Plus trimmer and have starting problems. It is relatively new and if you cannot fix it I will return it to the supplier. However, if it is me then... I have followed the...
To be honest, the unit sounds sounds like it only needs a minor carburetor adjustment. When these fuel systems are installed and the machines shipped to the dealers, sometimes small things are overlooked. In this case, your machine wasn't "set up" for the climate it is now being operated in. Elevation of the land can affect the way these machines operate also. I know your country is mountainous and the Victa is an Austrailian brand. I would return it to the dealer for warranty service under the premise of "difficult to start."
Jan 25, 2011 | Garden
Got the new Ryobi RHT2660DA petrol hedge trimmer today. Have mixed fuel to instructions and followed every step to the letter. It starts fine, but keeps stopping when I excelerate it, any ideas?
It is running too lean on the mixture, if it was new return it for re tuning, it will be an easy fix which will only take a few minutes.
Jan 21, 2011 | Ryobi Garden
Unable to prime Sirena Espresso Machine
n regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Nov 28, 2009 | Saeco Starbucks Sirena Espresso Machine
Mazda etude 160ie a/c cuts out after approx 45 min driving.
Could be an electrical part that only fails after getting really hot. Coils and ignition modules are known for this. Unfortunately, these parts cannot be tested for this heat-soak type problems, other than to see if spark quality at the plugs has degraded when failing. One other thought. A bad gas cap which is not allowing air to flow in as gas is used can cause this and that is a cheap part to replace just for grins.
Jan 10, 2009 | 2003 Mazda MPV
Garden Logo
29 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
