Question about Frigidaire FWS833A Top Load Washer
The unit has a sqealing noise at high spin speed. already put a new belt on didnot fix problem
    Scholar:
  • 91 Answers
Hi dear.according to your explanation,it does have bearing problem & needs to be replaced.Consult for service centre how much it can cost you & make your decision.I hope that helps.Thanks.
Posted on Sep 02, 2010
My washer machine working in all function but in the spin function the motor rotate slowly
there is a problem in the program board
the unit starts to spin slow as the water is pumped out
that is supposed to distribute the clothes for balance and then it goes into a high speed spin
you unit is not progressing to that high speed spin
Call a technician for a proper diagnosis and fix
Nov 06, 2016 | Washing Machines
My stackable washer is sqealing just before spin cycle
Common cause of this problem is The sound at high speed spin due to dry bearing of motor and wash tub. lubricate with high temprature grease.If you are not able to do.contact the mechanic
Mar 02, 2015 | Washing Machines
How do i fix the whining noise my 2009 kia sorento makes
may be your power steering pump whining. Check fluid first, then if it's up, start the car up and have someone turn the wheel back and forth a few times. Listen to see if there is more or less noise when this happens. Does the noise go away after it warms up?
Jan 27, 2013 | 2009 Kia Sorento 3.3
Mazda protege 2000 squealing from serpentine belt area check engine light on
it is the belt it is either to tight or not tight enough
Dec 14, 2012 | 2000 Mazda Protege
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
Loud sqealing tried changing the belt but it still
above your water pump there is a small hose that runs into it there check it make sure it is not leaking that will make it squeal and its cheap doesnt take much water for the belt to slip so?
Sep 27, 2009 | 1997 Ford F150 Regular Cab
Squealing noise (belt) and now the battery light is on. any idea what this could be?
Sqealing belt is loose belt. Battery light on could mean loose or failing aternator for same reason. If belt isn't loose, use belt dressing. If this is helpful, please rate as such. TY
Jan 29, 2009 | 2001 Chrysler Town & Country
RCA D52W19 - High Picth sqealing noise
Thats usually a sign of the flyback or HV Splitter nearing the end of their operational lifespan. However its not an exspensive fix unless done ay a repair shop then it can be a few hundred.
Apr 21, 2008 | RCA D52W19 52" Rear Projection Television
Frigidaire FWS833A Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
