Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F9 is on display of my fisher and paykel dishwaher what is the problem
  • Fisher and P... Master
  • 3,247 Answers
I am assuming the F9 is showing up only in one of the two drawers. It means the controller has a fault. Cannot do much short of replacing it.
Have you tried to turn the power off and back on?
It looks something like this. You could try checking with the controller on the other unit but don't want to end up with two faulty ones. So may have to order one and try.
Hope this helps. Please rate the solution.
Posted on Sep 03, 2010
E6 error code on fisher and paykel dishwaher
The code E6 is for the flood switch
Pull the appliance out, tip it back about 45 degrees and see if water runs out of the base.
If it does, drain the base (under where the tub) completely and the anti flood should reset.
If there is an aquastop device on your fill hose, after draining the base, turn off the water supply, disconnect the aquastop device and allow it to de-pressurize. Connect it back up and try again.
If it happens again, you'll need to check for a leak.
The normal cause is over foaming, using multifunction tablets and rinse aid, or just spilling rinse aid.
Dec 28, 2016 | Fisher and Paykel Washing Machines
How do I fix F9 fault for Fisher & Paykel dishdrawer DD60
This is a controller fault and could be due to number of reasons. Either the controller itself is not sensing the sensors or some sensor is faulty. If it is occuring consistently and turning mains power and on is making no difference, then it is something a techniician will have to look at.
Sep 20, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel DishwasherDW60CCX1 - bought new 22.5.12. Error code E9. How to fix this please, as not in the instructions book!!
The code like E9 or F9 in F&P dishwasher usually implies controller fault. No solution but to call authorised technician unless you know how to replace the controller. Need to have a diagnostic tool to check what is happening. You should still be under factory warranty.
Dec 22, 2012 | Fisher and Paykel Dishwashers
Fisher Paykel Smartdrive MW058K error code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jul 23, 2012 | Fisher and Paykel Fisher & Paykel Washer
F9 code with a spanner underneath
Its a most common problem in this kind of model. The reason for F9 display in your washer is that due to a electronic malfunction that occurred in your unit. You cant replace any of the faulty part in your washer and its very difficult to identify the faulty area in your unit. So if you think you can do it by your own then the answer is "NO".Best way to fix your problem is that call your authorized service centre and they will fix your problem for sure.
Thank you !!
Jun 18, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
F9 beeping
Its a most common problem in this kind of model. The reason for F9 display in your washer is that due to a electronic malfunction that occured in your unit. You cant replace any of the faulty part in your washer and its very difficult to identify the faulty area in your unit. So if you think you can do it by your own then the answer is "NO"..
Best way to fix your problem is that call your authorized service centre and they will fix your problem for sure..
Apr 04, 2010 | Fisher and Paykel 24 in. DD603H I Built-in...
F9 problem code Fisher and Paykel Dishwasher - Soft Touch
That's an electronics failure code. Bad news.
http://www.advantagesupplyfl.com/FisherPaykelDishwasherFaultCodes.html
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
1,150 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
