Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
My Shop Vac Series H87 will not power on. It is empty and the filter's clean. I looked under the troubleshooting section of www.shopvac.ca for instruction. They advised to hit the reset/breaker button. However, I don't know where to find that switch. Any suggestions? Thanks! -Spence
MakikiChris
  • 84 Answers
SOURCE: emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Posted on Aug 02, 2007
Buffalo12980
  • 625 Answers
SOURCE: my shop vac won't turn back on after emptying
I'm afraid you'll need to take it apart. the switch is mounted in a plastic holder in the top. While you got it apart and without it plugged in, check to see that both brushes are touching the commutator. there should be sufficient spring tension to hold the brushes against the spinning part [commutator] if even one brush isn't making contact it won't spin.
Posted on Sep 11, 2007
reddevil6
  • 1673 Answers
SOURCE: Shop Vac just stopped
Some do, but it would be in the open by the cord. But you could have a bad cord, switch, or a problem with the motor.
Posted on Mar 13, 2008
bozcro
  • 867 Answers
SOURCE: Shop Vac was working fine last time I used it.
try tapping the motor area with a piece of wood or something, damp usage may have seized it up a bit
Posted on Jun 24, 2009
SOURCE: shop vac 90L400 stopped working won't start
VERY Helpful Customer service, immediate solution was to send a new power unit no cost to me! Thank you Shop Vac!
Posted on Dec 17, 2009
Does shopvac series 90ln have brushes in motor & how to replace them
A lot of shop vac motors have brushes, due to the motor's power needs. Unplug it (obv) and get to taking off all the covers until it's just you and the motor. On most shop vacs, you shouldn't need to remove the impeller (fan), and it's better just left alone. The brushes are usually just under spring tension.
Jan 28, 2017 | Vacuums
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
Is the shopvac qsp 10 for water
yes it is wet and dry cac go to link below for deiails
http://www.shopvac.com/pdf/Shop-Vac-QSP.pdf
Nov 08, 2012 | Vacuums
Do you need a special filter for wet application
Yes. The following site shows the filters and which is used for what. Due to potential motor damage, I wouldn't use it without the proper filter.
http://www.shopvac.com/shopvac-accessories/Departments/Wet-Pickup.aspx
Jan 03, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
My basement is flooding and my 5 gal shop will not **** up the water. It works momentarily and then spits the water back out
You should remove the filter that is inside the vac. This should allow for the vac to **** up the water. But just in case that doesn't do it, here is a link to a site that may contain a free download of your manual:
www.shopvac.com/parts_pdfs.asp?p=%25&Submit=Search
Just look up your type of vac and click on it.
Good Luck!
Jim
Oct 01, 2010 | Shop Vac (464-38-10) Canister Wet/Dry...
Motor makes loud racket and smells like burning, but still works.
Bag? There is a paper filter and maybe a foam filter ... bag? Maybe this is a newer model that I am not familiar with. Anyway ... ...
It sounds like your motor has been eating dust. Please check here for your repair: http://www.shopvac.com/support/
Feb 21, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I have a 10 gallon Shop.Vac 3.0 but I don't have the instruction booklet. Do I take off the pleated "paper" filter to vacuum up water? Do I use the vac with no filter for liquid?
Yes you should remove the filter for liquids. If the filter is not removed the internal float stop will not operate correctly. This will lead to the liquid being drawn up into the impeller and around the motor.
However I still like to have something in place because in most instances the liquid you vacuum up will not be without some solids. So I like to use a foam insert. Places like Home Depot carries a universal insert that works great.
Hope that helps.
Sep 17, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
134 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
