Question about Garden
I have an old, but good Bosch AXT Rapid Shredder [2002ish]with 'lost' manual. How do I get the top lid off when tryimg to sort out a blockage, and [2] same question about the shredder chute
  • andrew_ridet Sep 03, 2010
    fairly helpful, thanks
  • 19,396 Answers
Hi.
Here a user manual.
You are not supposed to open the top lid. If there is blockage run the knives in opposite direction to remove blockage , operation is described in manual.
Posted on Sep 02, 2010
Bosch AXT 2200 HP shredder motor turns the wrong way
Try flipping the plug on the wall plug it in c which way the unplug rotate an plug it in again I no when working with. Motor proper polarity determined direction
May 21, 2014 | Bosch AXT 22 D Electric Drum Garden...
My chipper shredder is jammed
I hate to say it but sometimes it is harder to fix than normal. I had to use a small chisel once to chip away at scrap wood until I could get it to move. I don't know the model but it might be possible to use a small hand saw to cut at the knot. it is very troublesome to work on that problem
Mar 16, 2014 | Bosch AXT 22 D Electric Drum Garden...
Works in reverse but not forward
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck.
Apr 11, 2011 | Cross Infoguard Shredder SX102M
Following a paper jam which was resolved, the shredder still works but makes a rapid (about 2 per second) rapping sound each time it runs. {sort of like a projecting screw head is bumping its enclosure...
Normally when you hear noises that repeat it is an indication that a gear or gears are damaged...open the machine up and check...for parts assistance and pricing call Royal at 1-800-524-0799.
Sep 13, 2010 | Royal 150MX Cross-Cut Shredder
Daughter ghave me Bosch AXT 2000 Shredder as she was emigrating to Australia, no manual and I'm at a loss as to how to use it !! How do I get a Manaul??
google bosch and ask for a manual or if you are lucky most manuals are on line just takes a bit of time searching
Jul 09, 2010 | Heavy Machinery
We have a Bosch WFK 2401 that is approximately 8 years old. I am not sure what cycle it was on when all of a sudden a loud noise started coming from the washer. Sounded like a gear stripping. A loud...
Check to see if inner drum is loose indicating bearing problem..Also check two springs on top of tub evident with lid off they can snap/ good luck
Sep 29, 2009 | Bosch WFK 2401
I have a bosch dishwasher that wont drain
Question! Did u buy this from Bosch? If you did not, then your contract is with the Store you bought it from and NOT Bosch and you should be contacting them and they should sort the problem.
A blockage, can sometimes be solved by putting one of those diswasher cleaning tabs in the machine a couple of times and see if that sorts the problem for you.
I suggest do that first it is the cheapest option and then if that does not work ring who you bought it from whether that be a retailer or Bosch themselves.
Jun 18, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Broken Bosch AXT 2000 HP Shredder
Chances are there is a branch wedged in the blade assembly. Are you able to pull the starter cord? if not, you'll have to remove the housing that covers the blades and remove the blockage.
When you expose the blade use a bar to reverse the blade and release the tension, If it was blocked it should start up right away.
May 04, 2009 | Heavy Machinery
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
