Question about Cameras
I switched off the device and it remaind showing POWER OFF
  • Cameras Master
  • 4,924 Answers
Remove batteries and put them back after a while and power it on again ..and see what is going on ...It should be working ..
Posted on Sep 02, 2010
How do I 19 divided by 789
Remember 19 can also be written as 19.00000000, (or as many zeroes after the decimal as necessary) so:
___.024081115__
789)19.000000000
15.78
3.220
3.156
.06400
6312
880
789
910
789
1210
789
4210
3945
265
Depending on the accuracy of the desired result, continue as above until the remainder is zero or starts repeating. The work above shows the answer is .024081115 with still a remainder.
My calculator shows the answer as .024081153358682
Dec 17, 2014 | Computers & Internet
How do you make it show you the remander instead of a decimal
If you want just the remainder, use the remainder() function. For example, to find the remainder of 17 and 3, press MATH right-arrow 0 1 7 , 3 ENTER.
If you want to display a number as a fraction, use the >Frac command. For example, to display 17/3 as a fraction, press 17 / 3 MATH 1 ENTER.
Feb 18, 2013 | Texas Instruments TI-83 Plus Calculator
Pls help me my laser jet hp printer showing scanner error 12 how can i remove this error
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the device on.
Aug 20, 2011 | HP LaserJet M1005 Printer
What is base 6 of 486
for converting 486 to the base 10 to base 6 dived 486 by 6 and note the quotients and remainder.
486/6 = quotient = 81 remainder = 0.now divide quotient by 6 and note quotient and remainder.
81/6 = quotient 13 remainder= 3
13/6 = quotient 2 remainder = 1 .
2/6 = quotient 0 remainder= 2.
Hence reading remainder from below we get 2130.
So 486 tot he base 10 is equivalent to 2130 to the base 6.
Thank you.
Jun 25, 2010 | Mathsoft Solving and Optimization...
When i do a problem, the answer shows a number then the remainder shown 'E x' x is where the remainder numbers go. how do i get rid of the E and the remainders?
It sounds as if you're in either Scientific or Engineering notation. To switch to Normal:
Press MODE.
Highlight Normal on the first line and press ENTER.
Highlight Float on the second line and press ENTER.
Press 2ND QUIT to exit.
Feb 17, 2010 | Texas Instruments TI-84 Plus Calculator
It Keeps Freezing up and i want to know how to fix it
Try this - Reset the device 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Or you can try to force MSC modes 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC. If none of this helps you might need to reload and update to the latest firmware or try and force recovery mode. 1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off. 2. Slide the Hold switch so the orange portion shows. 3. On your PC, double-click My Computer 4. On your Sansa player, press and hold the REC button while connecting it to the PC. 5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer. This may not work on your player not sure of the Model cut off.
Jan 16, 2010 | SanDisk Sansa Clip MP3 Player
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
My TV click an comes on voice only and no picture
Loose grounds on the vertacal ic or the horizontal coil or a bad ground on a power resistor. Definitely a bad ground...Find someone to resolder these for you.
Sep 03, 2009 | Proton MM2701VT 27" TV
My device turns on but shows message ¨refresh database¨ it won´t do anything else, what can do?
HI,
Try these steps:
  STEP 1 - Reset the device
1. Slide the Power switch up and hold it for approximately 20 seconds.
2. Release the Power switch once the device is powered down.
3. Turn the device back on.
STEP 2 - Download and Install the Sansa Firmware Updater
Jan 29, 2009 | SanDisk Sansa e260 MP3 Player
Cameras Logo
13 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
