Question about Jandy Ray Vac Pool Cleaner for Inground Concrete
My ray vac stays in deep end of pool at the bottom where the intake is for the filter
3 Suggested Answers
SOURCE: Ray Vac moving slow, circles deep end, sticks on side of pool
I have the same problem and the best solution is to repair/replace the hydro timer kit. It has inner gears that are plastic and wear down and doesn't rotate through the cycle of water flo that changes it's direction. I'm in the process of exhaustive repair and I'm going to replace the hydro timer - (inside part only) and then see what happens. Moving the gears did change it's moving patterns tho.
Posted on Jun 06, 2009
  • 990 Answers
SOURCE: same prob. ray vac circles bottom of deep end.
Mabey the gears in the backup valve a small football in line about 18" from wall. Just pull it from the water if you have one that is about every one to two munites it should send a jet of water out the side of the backup valve for about ten or fifteen seconds. If it dosen't you need a new one . Quite often a more likliy problem is tight swivels your local pool store can ck these for you and the leingth of your hose should just make the far point of the pool so it streches the hose and pulls all the kinks and loops out. Your pool store can help you with much of this and they will check the whole unit if you bring it in to the store and will usually just charge for parts.
Posted on Aug 24, 2009
My pool sweep stays in the deep end and will not move to the shallow end of the pool
make sure you have proper flow rate and try shortening the length of the vac hose. this will change the pattern the machine uses
Jun 17, 2014 | Zodiac Baracuda Zippy Pool Cleaner
I have a jandy ray vac pool cleaner that just goes in circles in the deep end of the pool.
look at instruction manual there is a setting you probably have to set
Jun 01, 2014 | Pool & Spa
Deep end only
adjust floating handle
Jun 03, 2013 | Aqua Vac Tiger Shark
Jet Vac Will only clean the Deep end of the pool
How steep is the run from the deep end to the shallow end? Have you tried to adjust the nose wheel at all?
Apr 01, 2013 | Pentair Jet Vac Quick Disconnect Swivel...
Vac gets stuck in deep end and can't get to shallow end
What type of pool do you have? These specific pool cleaners are made for flat bottomed above ground pools. They are not made to move from deep end to shallow end. If you are using this on an in ground pool that has both shallow and deep or a dished above ground pool, you are not going to get accurate cleaning.
Mar 06, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Ray Vac cleans only in deep end
Make sure that your automatic pool cleaner doesn't have an obstruction in the hose that might not immediately be visible. This could cause it to circulate in one end of the pool. Also, check the water pressure to ensure that it has enough force to travel the entire pool.
Jun 27, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Same prob. ray vac circles bottom of deep end. tink2b3 suggested moving the gears? what does that mean?
Jun 09, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Need to get water of the bottom of the pool
there is a drain hole at the buttom of the deep end. need to clean out the drain before turning on the pump.
May 08, 2009 | Hayward SAND FILTER, PRO SERIES
Dec 19, 2008 | Jandy Ray Vac Pool Cleaner for Inground...
How to connect the vacuum system in the swwiming pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Generic problem for all Vacuums
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Jandy Ray Vac Pool Cleaner for Inground Concrete Logo
Top Jandy Garden Experts
Dennis Key
Dennis Key
john h
Are you a Jandy Garden Expert? Answer questions, earn points and help others
