Question about Bulova Watch
I have a pair of Sutus Quartz wrist watches, have they any value ?
The hands have come off my fossil FS3087 wrist watch. I would like to know how to take off the glass in order to fix it myself. Thank you
mcdevito75 here, In most cases the glass (crystal) come off or out thru the back of the watch which means you"ll have to remove the quartz mechanism, and that means removeing the stem, thse quartz stems are very prone to breaking while being removed form the quatrz mechanism and the cost of a repair may be more expensive then a whole new watch, shop around get a price from a small watch repair shop on repair verses a new Fossil watch.
Feb 09, 2011 | Fossil FS3087 Wrist Watch
DATE WONT CHANGE
If you have the crown in the first click position (date set position) the date set wheel is most likely damaged. Otherwise, if it does not change in 24 hours, it is the date wheel itself that is damaged.
This happens in all watches over time, as even quartz watches must technically be serviced every 3-5 years. 90% of manufacturers quote this as the standard service rate for quartz and mechanical watches.
If this watch has sentimental value, and you will want to contact a local Certified Master Horologist or Certified Quartz Technician about replacing the movement. Replacing Timex movements is generally more expensive than purchasing a new watch.
If the watch is still in warranty, you may consider contacting Timex about replacing the watch free of charge at: custserv@timex.com
Feb 04, 2011 | Timex Expedition 43892 Wrist Watch
I have a bretling colt quartz watch and the hour regester will not reset
Try pulling out the winding crown,then press the chrono pusher.This will advance the chrono hands.Each pusher will advance a different hand.
Aug 13, 2010 | Breitling Colt Quartz 820 Wrist Watch
I have a bulova 18K gold men's wrist watch, which says 3063-5020 AO in a square on the back. Swiss A6 18K. And it is a battery watch, and is still running any idea? of year or price it is very heavy on the...
mcdevito75 here, The movement number tells all, but I would figure the yaer somewhere in the 80"s and value at $250----$350.-- Accutron very collectable watch. Look for a small watch repair shop in your area for more accurate info. Hope this hepls.
Aug 02, 2010 | Accutron Swiss Watch by Bulova 26B44
New battery want work? I tried two new ones and nothing worked? Need help.
mcdevito75 here, You may need to start your watch by pressing the MODE button. Most quartz watches will stop once you"ve changed the battery, of course the possibility is there that the watch quartz has burnt out also. See a small watch repair shop in your area.
Jun 30, 2010 | Fossil BQ9177 Wrist Watch
Ladies rolex quartz geneve 59312
There is no such thing as Rolex Quartz 59312. Ether you got yo numbers wrong or it is a fake watch.
Rolex made quartz watches only in men's size.
W-Precision
Mar 16, 2010 | Rolex Daytona 116520 Wrist Watch
Can i replace automatic movement for quartz in a james bond model , and can i do this myself
You can if you have following:
1) Lathe technique skills,
2) Watchmaking skills,
3) Watch engineering knowledge,
4) All necessery watchmaking hand tools,
4) Watchmakers lathe,
6) Microdrill,
7) Omega or ETA manufactured quartz movement
8) Original Omega dial for this particular movement,
9) Watch hands for this particular dial.
At the very end your watch will have no market value at all exept sentimental value for yourself.
Rate me, please.
Aug 22, 2009 | Omega Seamaster 2253.80 Wrist Watch
I have agents rotary quartz with the number 3081 stamped on the back. the watch is oblong with a black black face and gold lettering and a date box. and gold intergrated strap. Would you please be able to...
Your watch is battery operated hence the term "quartz" All quartz watches are battery powered. As for value I'm not sure. The manufacturer of the module (mechanism inside) is a reasonable indicator of value. If its ETA then its in the upper range. You could try seeing if Rotary have a site if so they may allow you to identify details on age etc from the stamp numbers.
Jul 24, 2009 | Rotary Automatic Limited Edition Dark...
Watch.....
Rolex is very fine watch if you maintain it properly. Is it more accurate for keeping time than a quartz watch? No, even specs tell you that. Hope that helps you.
May 30, 2009 | Rolex Daytona 116520 Wrist Watch
Band adjustment
Use a pick tool and push the pins out the sides in either direction of the arrows.
Nov 17, 2007 | Fossil CH2331 Wrist Watch
Bulova Watch Logo
652 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
