4700 error code 10.70.03 & 10.70.02 - Office Equipment & Supplies
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Error code 59.90 on color laserjet 4700
Transfer belt motor error, either a bad motor or a bad transfer belt.
Service error 4cf0 hp 4700
Try removing the JetDirect card, then see if the machine will boot and print a test page. If it works without JetDirect, then try replacing the JetDirect card.
Oct 15, 2014 | HP LaserJet 4700 Printer
P0171 & p0174 2004 deville
For OBD code problems check the list of help links below. Click the link below to go through its procedure.
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
This will help.
Thanks.
Mar 01, 2012 | 2004 Cadillac Deville
Error codes 1133 & 1153 1998 chevy blazer
code P1133 is for a problem with 02 sensor bank one sensor one. this is the left 02 sensor in front of the cat. converter. code P1153 is for a problem with 02 sensor bank 2 sensor 1, which is located on the right side of engine in front of the cat. converter
Jul 07, 2011 | Chevrolet Blazer Cars & Trucks
How do I fix error code 49.4C02 on a HP 4700 color printer?
This error code code comes because of outdated firm ware you just have to update the firm ware and solve the problem.
Update the firmware on the HP Color Laser Jet 4700 printer to version 20091125 46.120.4 or later. This new firmware resolves the issue.
Thanks.
Have a great day.
Oct 08, 2010 | Computers & Internet
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Jul 02, 2009 | Sony UVW1800 VCR
Sharp ar 122 ccd trouble how to repaire
Sharp AR-122 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 23, 2009 | Sharp Office Equipment & Supplies
Paper tray will not go up or down. Cannot get it to move.
Sharp AR-650 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 19, 2009 | Sharp AR-650 Copier
592 people viewed this question
jasbo
jasbo
