Question about Ecoquest Fresh Air Air Purifier
Reset button I lost my Ecoquest Fresh Air Manuel when I moved and I do not remember how to reset the machine after replacing the lamp and fuse.
  • Anonymous May 24, 2008
    How to replace the lamp?? Do you rotate the blub when instaling or not?
    Please help.....thank you
I found a place on the internet that allowed me to down load a user's manual. It solved my problem. Thank you anyway.
Posted on May 11, 2008
I changed the bulb but it keeps saying replace bulb
Look through the settings to see if there is a reset option for warnings or for lamp warnings. Many products with lamps require you to not only replace the lamp but to reset the warning.
Oct 18, 2012 | Ecoquest Fresh Air Air Purifier
Fresh Air Maachine by Ecoquest
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
Jul 12, 2008 | Ecoquest Fresh Air Air Purifier
Perform cleaning on EcoQuest Fresh Air won't go away after pushing reset button
If you did not thoroughly clean the contacts for the ozone plate, the "Perform Cleaning" light will not reset.
May 05, 2012 | Ecoquest Fresh Air Air Purifier
Where can I find wiring diagram for Ecoquest air purifier. Replaced UV lamp and disconnected wires and cannot remember how to place them.
Try checking the contacts to the ozone plate. Or a wire may be loose--check the contacts and sometimes they need to be cleaned with alcohol.
Apr 19, 2012 | Ecoquest Fresh Air Air Purifier
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi is that?
I'm not sure if this is the answer, but did you turn the unit off, then turn it back on and press the reset button on the front?
Nov 23, 2009 | Ecoquest Fresh Air Air Purifier
Change to purify setting
Contact healthytech@triad.rr.com. They will be glad to help you.
Jun 06, 2009 | Ecoquest Breeze AT Living Air Purifier
How do you replace the lamp of an ecoquest air purifier?
Call toll free 1-877-710-0057 between 8: 00 AM and 5:00 PM Eastern time and they will gladly help you.
Dec 21, 2008 | Ecoquest Fresh Air Living Air Purifier
Replaced RCI Cell 2 times, light still doesn't come on
The U.V light is inside the RCI cell. If you replace the RCI, it has been ok. Please don't mind the screen display.
Oct 09, 2008 | Ecoquest Fresh Air Air Purifier
EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Jul 19, 2008 | Ecoquest Fresh Air Air Purifier
Replacing uv lamp in Ecoquest air purifier
Hi FCfogl, Here's you answer. Go to the URl below for detailed instructions with pictures. http://www.airpurifierrepair.com/PageInfo.aspx?page=ReplaceUV Hope this helps
Sep 25, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
317 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
